Issue with MySQL and Ignition
Hello Guys, i have a problem with Mysql and Ignition . Although it seems that Ignition Located the Mysql Database ,nothing are store in the database. I saw the video provided by ingition but i have not seen any example of it actual working.
I have created a database with MYSQL i have established the connection between Ignition and the database but still have no values stored in the Database. But if i use the tags for the PowerGraph i can see the historical values on the graph.
Can someone guide me please through it ? My experience with the databases are limited.
Thanks in advance.
Power Chart?
How are you inspecting the database?
yes sorry i meant power Chart. How can i check if data are flowing to my database?
If you don't have a database development then you can use the named query editor. Select the Authoring tab, select the database from the dropdown and browse the tasks and columns on the right.
If there are no values in your database, then what values are being shown on the Power Chart?
The Power Chart only works with the Tag Historian, so you must have a Tag with history configured and your database set as the Provider.
Hi Irose see below screenshot
I dont know who to map my database so it will be regognize where the values should be store. With SQlite it was much easier to set it and store the Values. Mysql is different.
With SQlite you set the database , the device name for example and the values as tags which you want to record.
Hi Transistor this i what i see now
Try this in the Query text field:
SELECT *
FROM sqt_data_1_2024_09
Then open the Testing tab and hit the Execute Query button.
If you want to get fancy then do a join on the sqlth_te table to retrieve the tagpath.
I found this and yes i have data inside this table. But i want to have for example 30 values stored with the date and time. how can i do that? this is storing only one value atm and i have configured in ingition 6 tags for testing . and only one tag is stored
i thought i could create the tables by myself and only the name should match to be able to store the values. Do you have any example to show me ?
im currently using Mysql workbench and Dbeaver to check the values.
All you need to do is configure a tag with history, and set the history provider. In your example the only option that you will have available is ‘IgnitionDB’.
Once you have a tag, the historian will take care of creating the proper tables for you and start recording values into the data table.
Have a read through the following articles.
Pay particular attention to the data compression methods.
