Just got a new code signing certificate and am getting the following when trying to install the module.
com.inductiveautomation.ignition.gateway.modules.ModuleVerificationException: module verification failed
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.verifyModuleSignatures2(ModuleManagerImpl.java:1604)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.loadModule(ModuleManagerImpl.java:1304)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$2.call(ModuleManagerImpl.java:765)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:948)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:738)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1904)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1857)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:930)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:1005)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:539)
Caused by: java.io.IOException: signature verification failed
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.verifyModuleSignatures2(ModuleManagerImpl.java:1596)
