Issue with Perspective Table Showing seconds since epoch instead of formatted date
I have a table in perspective thats supposed to be showing me a date in a column, but instead it seems to be showing seconds since the epoch.
I have the column render set to date, and the format specified but it doesn’t seem to change anything.
Thanks for reporting this.
This is a known issue that has a fix already in the code base that will be in the 8.0.3 version.
Thanks,
Jonathan C
in v8.0.16 it doesn`t work
I can`t change format! How I can do it?
It does work in 8.0.16.
Please verify that you have a column configuration in place for the column which contains your date.
In the following screenshots, I'm using a Dataset with columns named "str" and "Date".
No column configuration specified for the column (field setting is empty):
Now the field property is correctly specified to target my column named "Date" (you can see that the column is now rendered correctly):
After changing the dateFormat property to render as date and time:
