    "type": "ia.container.flex",
    "version": 0,
    "props": {
      "direction": "column",
      "style": {
        "overflow": "hidden"
    "meta": {
      "tooltip": {},
      "name": "root"
    "position": {},
    "custom": {},
    "children": [
        "type": "ia.display.icon",
        "version": 0,
        "props": {
          "color": "#000000"
        "meta": {
          "name": "Icon"
        "position": {
          "shrink": 0,
          "basis": "50%"
        "custom": {},
        "propConfig": {
          "props.style.backgroundColor": {
            "binding": {
              "type": "property",
              "config": {
                "path": "view.params.stateColor"
        "type": "ia.display.label",
        "version": 0,
        "props": {
          "textStyle": {
            "marginBottom": "90%",
            "rotate": "90deg",
            "textAlign": "left"
          "style": {
            "classes": "Label/text-medium",
            "color": "--neutral-60"
        "meta": {
          "name": "Label"
        "position": {
          "shrink": 0,
          "basis": "50%"
        "custom": {},
        "propConfig": {
          "props.text": {
            "binding": {
              "config": {
                "path": "view.params.name"
              "transforms": [
                  "expression": "try \r\n\t(split(split({value}, \"_\")[1,0],(\"-|_0|STA|SM|OPMODE|RT|PT|ASM|ST00\"))[1,0], split({value}, \"_\")[1,0])\r\n\r\n//split(\"STA010\",\"(_0|STA0|STA|RT|ASM|ST00)\")[0,0]\r\n",
                  "type": "expression"
                  "formatType": "numeric",
                  "formatValue": "number",
                  "type": "format"
              "type": "property"
    "propConfig": {
      "custom.stateColor": {
        "binding": {
          "config": {
            "expression": "//lookup({Tesla/Line/StateDefinition},{view.params.state},\"#00000\",\"id\",\"color\")\r\n{view.params.stateColor}"
          "type": "expr"
      "meta.tooltip.text": {
        "binding": {
          "config": {
            "expression": "\"Details: \"+{view.params.detail}+\" \\nState: \" +{view.params.stateName}"
          "type": "expr"
