Hi all,
I am trying to connect an Omron PLC to ignition through the CJ1W-ETN21 expansion module using Omron FINS/TCP protocol but cannot establish communication.
I have had no issues connecting to Omron PLCs with the ethernet port directly on the CPU but can't seem to figure it out for the expansion module.
I have set the IP address, subnet mask, gateway address, conversion type to combined, and I adjusted the switches on the module to match the last octet of the IP address.
Through ignition, I tried to make the connection as I did for the other Omron PLCs. I created the device connection, selected Omron FINS/TCP driver, input a name and the hostname, and left the other settings as they were defaulted.
Is there a step that I am missing? What needs to be done differently to be able to connect through the expansion module?
Thanks!
