Issues reading tags from AB EN4TR - Connects but tags Uncertain_LastKnownValue quality
I’m testing comms to an L83 via an AB EN4TR however I’m unable to get it reading tags. It connects fine but tags are coming up with:
[2, Uncertain_LastKnownValue(“Whatever was updating this value has stopped doing so.”), Thu Feb 03 09:37:20 ACDT 2022 (1643843240797)]
Swapping back to talking via the onboard L83 ethernet works fine.
Any ideas? What loggers should I be turning on?
This is what I see in the OPC browser, no tags showing up:
and their values:
Edit:
I noticed this in logs:
com.digitalpetri.enip.cip.CipResponseException: status=0x01 [connection failure] , additional=[0x032F]
at com.digitalpetri.enip.cip.services.GetAttributeListService.decodeResponse(GetAttributeListService.java:45)
at com.digitalpetri.enip.cip.services.GetAttributeListService.decodeResponse(GetAttributeListService.java:12)
at com.digitalpetri.enip.cip.services.UnconnectedSendService.decodeResponse(UnconnectedSendService.java:122)
at com.digitalpetri.enip.cip.CipClient.lambda$invoke$2(CipClient.java:124)
at java.base/java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.complete(Unknown Source)
at com.digitalpetri.enip.cip.CipClient.lambda$sendUnconnectedData$8(CipClient.java:222)
at com.digitalpetri.enip.EtherNetIpClient$PendingRequest.lambda$new$0(EtherNetIpClient.java:412)
at com.digitalpetri.enip.EtherNetIpClient.onChannelRead(EtherNetIpClient.java:220)
at com.digitalpetri.enip.EtherNetIpClient.access$900(EtherNetIpClient.java:50)
at com.digitalpetri.enip.EtherNetIpClient$EtherNetIpClientHandler.lambda$channelRead0$0(EtherNetIpClient.java:346)
What can cause the CIP connection to fail?
Womp womp. That additional error code falls into the “vendor specific” range of 0x0320-
0x07FF.
The “good luck, son!” range :frowning: I’ll get in touch with RA, cheers
I think maybe something to do with CIP security or firewall/whitelist or something?
Ooo, i’ll* have a look, thanks
*I’ll get my PLC mate to have a look
There’s a reference to 0x032F in this doc as being “0x032F: Ingress rule deny non-secure.”.
