We performed an upgrade from 7.3 to 7.4 a while back. I noticed today when accessing the Gateway interface over HTTPS that “the identify of this website has not been verified.” When I looked further, it’s showing that the certificate was issued to Ignition by Ignition … I’m assuming this is a default, self-signed certificate of sorts.
EDIT: Sorry, meant to say that we had previously created the keystore ourselves and imported our own certificates.
Any ideas? Below is the contents of install_log.text if it helps …
[quote]Log started 04/08/2012 at 22:46:07
Preferred installation mode : win32
Trying to init installer in mode win32
Mode win32 successfully initialized
[22:46:13] Begin: project.Pre-installation Actions
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\Inductive Automation\Ignition Location. Setting variable installdir_32 to empty value
[22:46:13] Project.pre-installation: installdir set to C:\Ignition,
datadir set to C:\Ignition/data,
logsdir set to C:\Ignition/logs,
userlibdir set to C:\Ignition/user-lib
[22:46:16] End: project.Pre-installation Actions
[22:46:16] Begin: Ignition Platform.Pre-installation Actions
[22:47:24] End: Ignition Platform.Pre-installation Actions
Preparing to Install
[22:47:39] Begin: Ignition Platform.Ready To Install Actions
Stopping Ignition
Executing C:\Ignition/stop-ignition.bat “” nopause
Script exit code: 0
Script output:
WARN | wrapper | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | C:\Ignition\wrapper-license.conf
WARN | wrapper | trying the system encoding.
wrapper | Stopping the Ignition Gateway service…
Unable to rename log file logs\wrapper.log to logs\wrapper.log.1. File is in use by another application.
wrapper | Waiting to stop…
wrapper | Ignition Gateway stopped.
Script stderr:
Upgrading previous installation
[22:48:00] End: Ignition Platform.Ready to Install Actions
Directory already exists: C:\Ignition
Creating directory C:\Ignition\lib
Creating directory C:\Ignition\lib\core
Creating directory C:\Ignition\lib\core\client
Creating directory C:\Ignition\lib\core\common
Creating directory C:\Ignition\lib\core\designer
Creating directory C:\Ignition\lib\core\gateway
Creating directory C:\Ignition\lib\core\launch
Creating directory C:\Ignition\tomcat
Creating directory C:\Ignition\tomcat\conf
Creating directory C:\Ignition\tomcat\webapps
Creating directory C:\Ignition\tomcat\webapps\main
Creating directory C:\Ignition\tomcat\webapps\main\WEB-INF
Creating directory C:\Ignition\tomcat\webapps\main\WEB-INF\lib
Creating directory C:\Ignition\tomcat\webapps\ROOT
Creating directory C:\Ignition\tomcat\webapps\ROOT\WEB-INF
Unpacking files
Unpacking C:\Ignition\ignition.ico
Unpacking C:\Ignition\lib\catapult.jar
Unpacking C:\Ignition\lib\commons-cli-1.2.jar
Unpacking C:\Ignition\lib\servlet-api.jar
Unpacking C:\Ignition\lib\TimingFramework-1.0.jar
Unpacking C:\Ignition\lib\wrapper.jar
Unpacking C:\Ignition\lib\core\gateway\activation_ws.jar
Unpacking C:\Ignition\lib\core\gateway\commons-dbcp-1.2.2.jar
Unpacking C:\Ignition\lib\core\gateway\commons-discovery-0.2.jar
Unpacking C:\Ignition\lib\core\gateway\commons-logging-1.1.1.jar
Unpacking C:\Ignition\lib\core\gateway\commons-pool-1.4.jar
Unpacking C:\Ignition\lib\core\gateway\HASPJava.dll
Unpacking C:\Ignition\lib\core\gateway\ignition32.dll
Unpacking C:\Ignition\lib\core\gateway\ignition64.dll
Unpacking C:\Ignition\lib\core\gateway\jaxp-api.jar
Unpacking C:\Ignition\lib\core\gateway\jaxrpc-api.jar
Unpacking C:\Ignition\lib\core\gateway\libignition-hpux.so
Unpacking C:\Ignition\lib\core\gateway\simpleorm.jar
Unpacking C:\Ignition\lib\core\gateway\wsdl4j.jar
Unpacking C:\Ignition\lib\core\launch\launchclient.jar
Unpacking C:\Ignition\lib\core\launch\launchclient.jar.pack.gz
Unpacking C:\Ignition\tomcat\conf\web.xml
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\wicket-datetime.jar
Unpacking C:\Ignition\lib\annotations-api.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\context-bootstrap.jar
Unpacking C:\Ignition\gwcmd.bat
Unpacking C:\Ignition\lib\el-api.jar
Unpacking C:\Ignition\lib\core\gateway\hasp-srm-api.jar
Unpacking C:\Ignition\install-ignition.bat
Unpacking C:\Ignition\launch-homepage.bat
Unpacking C:\Ignition\launch-gcu.bat
Unpacking C:\Ignition\lib\core\gateway\jax-qname.jar
Unpacking C:\Ignition\lib\core\gateway\jaxrpc-spi.jar
Unpacking C:\Ignition\lib\core\gateway\jaxrpc.jar
Unpacking C:\Ignition\lib\core\gateway\jdbc-helper.jar
Unpacking C:\Ignition\lib\core\gateway\libignition-arm5.so
Unpacking C:\Ignition\lib\core\gateway\libignition-x64.so
Unpacking C:\Ignition\lib\core\gateway\libignition-x86.so
Unpacking C:\Ignition\lib\core\gateway\libignition.jnilib
Unpacking C:\Ignition\lib\slf4j-api-1.5.3.jar
Unpacking C:\Ignition\lib\core\gateway\saaj-api.jar
Unpacking C:\Ignition\lib\core\gateway\saaj.jar
Unpacking C:\Ignition\start-ignition.bat
Unpacking C:\Ignition\stop-ignition.bat
Unpacking C:\Ignition\lib\slf4j-log4j12-1.5.3.jar
Unpacking C:\Ignition\lib\tablelayout.jar
Unpacking C:\Ignition\tomcat\ssl.key
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\slf4j-api.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\slf4j-log4j.jar
Unpacking C:\Ignition\uninstall-ignition.bat
Unpacking C:\Ignition\lib\tomcat-juli.jar
Unpacking C:\Ignition\wrapper-license.conf
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\web.xml
Unpacking C:\Ignition\tomcat\webapps\ROOT\WEB-INF\web.xml
Unpacking C:\Ignition\tomcat\webapps\ROOT\WEB-INF\web.xml_clean
Unpacking C:\Ignition\lib\catalina.jar
Unpacking C:\Ignition\lib\jide-common.jar
Unpacking C:\Ignition\lib\jide-components.jar
Unpacking C:\Ignition\lib\log4j-1.2.15-min.jar
Unpacking C:\Ignition\lib\mail.jar
Unpacking C:\Ignition\lib\tomcat-coyote.jar
Unpacking C:\Ignition\lib\core\client\client-api.jar.pack.gz
Unpacking C:\Ignition\lib\core\common\bcprov.jar
Unpacking C:\Ignition\lib\core\common\bcprov.jar.pack.gz
Unpacking C:\Ignition\lib\core\common\common.jar
Unpacking C:\Ignition\lib\core\common\common.jar.pack.gz
Unpacking C:\Ignition\lib\core\common\jython25.jar
Unpacking C:\Ignition\lib\core\common\jython25.jar.pack.gz
Unpacking C:\Ignition\lib\core\designer\designer.jar.pack.gz
Unpacking C:\Ignition\lib\core\designer\jide.jar.pack.gz
Unpacking C:\Ignition\lib\core\gateway\axis.jar
Unpacking C:\Ignition\lib\core\gateway\gateway-api.jar
Unpacking C:\Ignition\lib\core\gateway\gateway.jar
Unpacking C:\Ignition\lib\core\gateway\HASPJava_x64.dll
Unpacking C:\Ignition\lib\core\gateway\hsqldb.jar
Unpacking C:\Ignition\lib\core\gateway\jaxrpc-impl.jar
Unpacking C:\Ignition\lib\core\gateway\jgroups-all.jar
Unpacking C:\Ignition\lib\core\gateway\saaj-impl.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\joda-time.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\log4j.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\wicket-extensions.jar
Unpacking C:\Ignition\tomcat\webapps\main\WEB-INF\lib\wicket.jar
Unpacking files
Unpacking C:\Ignition\hasp_windows_x64_78934.dll
Unpacking C:\Ignition\IgnitionGateway.exe
Directory already exists: C:\Ignition\lib
Unpacking files
Unpacking C:\Ignition\lib\wrapper-windows-x86-64.dll
Directory already exists: C:\Ignition\user-lib\modules
Unpacking files
Unpacking C:\Ignition\user-lib\modules\User Manual-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\SQL Bridge-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\Vision-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\OPC-UA-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\Mobile-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\Allen-Bradley Drivers-module.modl
Unpacking files
Unpacking C:\Ignition\user-lib\modules\OpcCom-module.modl
[22:48:19] Begin: Ignition Platform.Post-installation Actions
Upgrading ignition.conf
Executing C:/Java/jdk1.7.0_03/jre/bin/java.exe -classpath “lib\core\common\common.jar” com.inductiveautomation.ignition.common.upgrader.Upgrader “C:\Ignition” “C:\Ignition/data” “C:\Ignition/logs” file=ignition.conf
Script exit code: 0
Script output:
Script stderr:
Installing Windows service
Executing C:\Ignition/install-ignition.bat “” nopause
Script exit code: 0
Script output:
wrapper | Ignition Gateway service installed.
Script stderr:
[22:48:21] End: Ignition Platform.Post-installation Actions
Installation completed
Log finished 04/08/2012 at 22:48:22
[22:48:24] Begin: project.Final Page Actions
Executing C:\Ignition/start-ignition.bat “” nopause
Script exit code: 0
Script output:
wrapper | Starting the Ignition Gateway service…
wrapper | Ignition Gateway started.
Script stderr:
Executing C:/Java/jdk1.7.0_03/jre/bin/java.exe -classpath “.;lib/*” com.inductiveautomation.catapult.control.GatewayControlUtil true logsDir=logs
Script exit code: 0
Script output:
Script stderr:
[22:49:06] End: project.Final Page Actions
[/quote]
