Hi, we are preparing an update of ignition 7.9 to 8.1 of our production server. To this end, we prepared a testing instance running 7.9.18 (our production version) with a copy of the production gateway and executed the 8.1 installer:
sudo ./ignition-8.1.20-linux-64-installer.run
(The command shows version 8.1.20, although the latest version is .23, but the outcome was the same)
After running the installer I get an "Ignition Successfully Upgraded" but the gateway fails to start:
WrapperSimpleApp Error: Unable to locate the class com.inductiveautomation.catapult.Catapult : java.lang.ClassNotFoundException: com.inductiveautomation.catapult.Catapult
Note: I also get the same error message when attempting to upgrade Ignition by using the Restore feature. That is, push the 7.9.18 .gwbk file into a fresh installation of Ignition 8.1.
I'm not sure what to do to solve this problem, and I couldn't find any helpful tips in the forum. Does anyone have any advices?
Best regards, Guilherme.
wrapper.log (297.9 KB)
Can you share your ignition.conf file? It looks like something weird may be going on there:
WARN | wrapper | 2023/01/11 17:10:42 | The "wrapper.java.classpath.3" property was redefined on line #61 of configuration file: /usr/local/bin/ignition/data/ignition.conf
WARN | wrapper | 2023/01/11 17:10:42 | Old Value wrapper.java.classpath.3=lib/core/gateway/*
WARN | wrapper | 2023/01/11 17:10:42 | New Value wrapper.java.classpath.3=/lib/core/common/org.eclipse.jgit-5.1.3.201810200350-r.jar
Of course, it is attached.
On the production server we installed git as an attempt to create a version control system for the various scripts and graphical components.
ignition.txt (8.7 KB)
Fix the numbering in that section so 3 isn't re-defined:
wrapper.java.classpath.1=lib/wrapper.jar
wrapper.java.classpath.2=lib/core/common/*
wrapper.java.classpath.4=/lib/core/common/org.eclipse.jgit-5.1.3.201810200350-r.jar
wrapper.java.classpath.5=/lib/core/common/jsch-0.1.54.jar
wrapper.java.classpath.6=/lib/core/common/commons-compress-1.5.jar
wrapper.java.classpath.7=/lib/core/common/JavaEWAH-0.3.2.jar
You can probably just remove 4-7 all together, you don't need to explicitly specify them when lib/common/* is already on the classpath. It may also be incorrect that they are prefixed with /, because it's probably looking for them at the absolute path of /lib/core/common/<foo> and not the relative path.
It was right in front of me. It is working now. Thank you for the help! And apologies for not presenting a more challenging bug
