Buenas tardes su ayuda por favor:
al tratar de hacer la conexion con mysql8 con jasperReport 6 desde Netbean 8.2
he tratad con varios mysql-conector-java-5.1.23.jar, mysql-conector-java-5.1.49.jar, mysql-connector-java-8.0.20.jar, ninguno funciona simpre el mismo mensaje:
Exception
Message:
java.sql.SQLException: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
Level:
SEVERE
Stack Trace:
com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1074)
com.mysql.jdbc.SQLError.createSQLException(SQLError.java:988)
com.mysql.jdbc.SQLError.createSQLException(SQLError.java:974)
com.mysql.jdbc.SQLError.createSQLException(SQLError.java:919)
com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1062)
com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3556)
com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2513)
com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)
com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:822)
com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
java.lang.reflect.Constructor.newInstance(Constructor.java:423)
com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)
com.jaspersoft.ireport.designer.connection.JDBCConnection.getConnection(JDBCConnection.java:140)
com.jaspersoft.ireport.designer.connection.JDBCConnection.test(JDBCConnection.java:449)
com.jaspersoft.ireport.designer.connection.gui.ConnectionDialog.jButtonTestActionPerformed(ConnectionDialog.java:335)
com.jaspersoft.ireport.designer.connection.gui.ConnectionDialog.access$300(ConnectionDialog.java:43)
com.jaspersoft.ireport.designer.connection.gui.ConnectionDialog$4.actionPerformed(ConnectionDialog.java:290)
javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
java.awt.Component.processMouseEvent(Component.java:6539)
javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
java.awt.Component.processEvent(Component.java:6304)
java.awt.Container.processEvent(Container.java:2239)
java.awt.Component.dispatchEventImpl(Component.java:4889)
java.awt.Container.dispatchEventImpl(Container.java:2297)
java.awt.Component.dispatchEvent(Component.java:4711)
java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
java.awt.Container.dispatchEventImpl(Container.java:2283)
java.awt.Window.dispatchEventImpl(Window.java:2746)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
java.awt.EventQueue.access$500(EventQueue.java:97)
java.awt.EventQueue$3.run(EventQueue.java:709)
java.awt.EventQueue$3.run(EventQueue.java:703)
java.security.AccessController.doPrivileged(Native Method)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
java.awt.EventQueue$4.run(EventQueue.java:733)
java.awt.EventQueue$4.run(EventQueue.java:731)
java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
org.netbeans.core.TimableEventQueue.dispatchEvent(TimableEventQueue.java:159)
java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
java.awt.Dialog.show(Dialog.java:1084)
java.awt.Component.show(Component.java:1671)
java.awt.Component.setVisible(Component.java:1623)
java.awt.Window.setVisible(Window.java:1014)
java.awt.Dialog.setVisible(Dialog.java:1005)
com.jaspersoft.ireport.designer.connection.gui.ConnectionsDialog.jButtonNewParameterActionPerformed(ConnectionsDialog.java:578)
com.jaspersoft.ireport.designer.connection.gui.ConnectionsDialog.access$400(ConnectionsDialog.java:47)
com.jaspersoft.ireport.designer.connection.gui.ConnectionsDialog$7.actionPerformed(ConnectionsDialog.java:221)
com.jaspersoft.ireport.designer.connection.gui.ConnectionsDialog.setVisible(ConnectionsDialog.java:651)
com.jaspersoft.ireport.designer.menu.DatasourcesAction.performAction(DatasourcesAction.java:46)
org.openide.util.actions.CallableSystemAction$1.run(CallableSystemAction.java:130)
org.openide.util.actions.ActionInvoker$1.run(ActionInvoker.java:95)
org.openide.util.actions.ActionInvoker.doPerformAction(ActionInvoker.java:116)
org.openide.util.actions.ActionInvoker.invokeAction(ActionInvoker.java:99)
org.openide.util.actions.CallableSystemAction.actionPerformed(CallableSystemAction.java:127)
java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1007)
