I’m having the same issue since upgrading to 8.0.16.
15:08:34.440 [AWT-EventQueue-0] ERROR Vision.Components.AdvancedTable - Error invoking extension method.
org.python.core.PyException: Traceback (most recent call last):
File "<extension-method onCellEdited>", line 53, in onCellEdited
File "<module:shared.Kanoa.WIP>", line 242, in updateLineProductionData
File "<module:shared.Kanoa.WIP>", line 1184, in writeLineProductionInfoToTable
INSERT INTO lineProductionData
(lineType, modeColor, Site, Area, Validated, [Equipment Path], [Equipment Name], [Equipment Mode Name], [Equipment Mode Type], [Work Order], [Product Code], [Mode Begin Time], [Mode End Time], [Mode Duration], [OEE Infeed Count], [Infeed Rate], Target, Units, [Rate Efficiency], [First Quality], [Quality Status], [OEE Outfeed Count], [OEE Reject Count], [Unplanned Downtime], [Line Downtime Occurrence Count])
VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?)
, [Batch, #00FF00, Conway, Resin, true, Chemical\Conway\Resin\Reactor K1, Reactor K1, Production, Production, 0003162587, RPPC2603, Fri Jan 03 15:35:01 PST 2020, Fri Jan 03 23:04:30 PST 2020, 7.491388888888889, , , , , , 1.0, Approved, 18900, , , ], IGN_CUSTOM, , true, false)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:413)
at org.python.pycode._pyx191.writeLineProductionInfoToTable$19(<module:shared.Kanoa.WIP>:1186)
at org.python.pycode._pyx191.call_function(<module:shared.Kanoa.WIP>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:139)
at org.python.core.PyFunction.__call__(PyFunction.java:413)
at org.python.pycode._pyx191.updateLineProductionData$2(<module:shared.Kanoa.WIP>:248)
at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
at org.python.core.PyFunction.__call__(PyFunction.java:434)
at org.python.pycode._pyx212.onCellEdited$1(<extension-method onCellEdited>:77)
at org.python.pycode._pyx212.call_function(<extension-method onCellEdited>)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:456)
at org.python.core.PyFunction.__call__(PyFunction.java:451)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:151)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Model.setValueAt(VisionAdvancedTable.java:1799)
at com.jidesoft.grid.TableModelWrapperImpl.setValueAt(Unknown Source)
at com.jidesoft.grid.DefaultTableModelWrapper.setValueAt(Unknown Source)
at java.desktop/javax.swing.JTable.setValueAt(Unknown Source)
at com.jidesoft.grid.JideTable.editingStopped(Unknown Source)
at java.desktop/javax.swing.AbstractCellEditor.fireEditingStopped(Unknown Source)
at java.desktop/javax.swing.DefaultCellEditor$EditorDelegate.stopCellEditing(Unknown Source)
at java.desktop/javax.swing.DefaultCellEditor.stopCellEditing(Unknown Source)
at de.javasoft.plaf.synthetica.SyntheticaDefaultTableCellEditor.stopCellEditing(SyntheticaDefaultTableCellEditor.java:123)
at java.desktop/javax.swing.DefaultCellEditor$EditorDelegate.actionPerformed(Unknown Source)
at java.desktop/javax.swing.JTextField.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.JTextField.postActionEvent(Unknown Source)
at java.desktop/javax.swing.JTextField$NotifyAction.actionPerformed(Unknown Source)
at java.desktop/javax.swing.SwingUtilities.notifyAction(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyBinding(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyBindings(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(
... 78 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to decode arguments
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:282)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
... 76 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: failed to read class descriptor
at java.io.ObjectInputStream.readNonProxyDesc(null)
at java.io.ObjectInputStream.readClassDesc(null)
at java.io.ObjectInputStream.readOrdinaryObject(null)
at java.io.ObjectInputStream.readObject0(null)
at java.io.ObjectInputStream.readArray(null)
at java.io.ObjectInputStream.readObject(null)
at com.inductiveautomation.ignition.common.Base64.decodeToObjectFragile(Base64.java:985)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunPrepStmt.runUpdateQuery(RunPrepStmt.java:43)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:25)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:68)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(null)
