Good morning.
After upgrading from Ignition 7.9.9 to Ignition 8.0.6, all global resources (libraries and templates) have been moved to the “global” project. This is fine, but now when I update a function in a shared script, the changes are refreshed correctly in the designer, but not in the client (runtime).
You can see it in this video:
https://drive.google.com/open?id=1PhJtnBoleI3pVmfRgjBQyPpozmBAo_4x
To correct the problem, I have to close the designer, clear the cache and reopen the designer:
https://drive.google.com/open?id=1ge6wADsBjso0YiLU_7nEOI-ejX79qlEm
This incident also occurs in some "SharedTemplates".
If you try to reproduce the issue, you need to know that I have unchecked the “Allow Override” option in all shared resources (libraries and templates)
Best regards.
