hello.
When I work on the vision screen and run it on the client, the following error message appears and the screen does not change.
File "<event:actionPerformed>", line 6, in <module>
java.lang.OutOfMemoryError: Java heap space
at java.base/java.util.ArrayList.grow(Unknown Source)
at java.base/java.util.ArrayList.add(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endObject(ObjectDeserializationHandler.java:52)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.foundObject(XMLDeserializer.java:960)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onRef(XMLDeserializer.java:908)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$MultiParseContext.onRef(XMLDeserializer.java:773)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:121)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeMultiple(XMLDeserializer.java:594)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor$TemplatePreDeserializeVisitor.loadInstances(ComponentVisitor.java:202)
at com.inductiveautomation.factorypmi.application.FPMIWindow.initializeUIRoot(FPMIWindow.java:310)
at com.inductiveautomation.factorypmi.application.FPMIWindow.initialize(FPMIWindow.java:284)
at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:540)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:192)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:184)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$swapWindow$0(NavUtilities.java:197)
java.lang.OutOfMemoryError: java.lang.OutOfMemoryError: Java heap space
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:461)
at org.python.core.PyObject.__call__(PyObject.java:465)
at org.python.pycode._pyx5.f$0(<event:actionPerformed>:6)
at org.python.pycode._pyx5.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:207)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:300)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at jdk.proxy2/jdk.proxy2.$Proxy51.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.OutOfMemoryError: Java heap space
Ignition v8.1.37 (b2024013011)
Java: Azul Systems, Inc. 17.0.9
Did this happen because the screen capacity was too large?
In this case, is it because the heap memory is small? Please tell me the solution.
thank you
