I would like to use the enter key after I have keyed in a value in the numeric text field to run a script when I press the enter key. Is there a simple way to do this other than writing a script module to define a Robot and KeyEvent from java.awt?
You can put the following on a keyPressed event:
if event.keyCode == event.VK_ENTER:
#do something
For more information about keyboard events:
inductiveautomation.com/support/ … _types.htm (under “key events” header)
Great, thank you
