Java concerns with Ignition
I have a customer that has concerns about Java and the security concerns around Java. Is there a white paper or article that can address this?
This customer’s IT department is hestitant to install Ignition on their server.
That’s a really old document. Even pitches java webstart as if it is current. Probably time to update it. A pointer to the log4j statement might be more helpful.
Yep, probably should…
There was an announcement the last Thursday (2022-03-31, as of this writing) on a zero-day using Spring Framework. I don’t know if it applies to anything IA related.
It does not.
Didn’t think so, but I’m sure there will be a flood of new threads…
EDIT: Link to the Log4J statement
Perhaps. I wrote a one-line response last week and we’re prepared with an official response if necessary, but unless inbound inquiries ramp up to the log4j CVE levels I don’t think we’ll explicitly announce anything.
So far there’s been almost no chatter about this.
The overall tl;dr on Java “security” is that it’s a lot of FUD that mostly dates back to when applets were an extant thing. In that context, running arbitrary code on your machine that can freely access your filesystem just by visiting a webpage was terrible for security…but it’s not really Java that’s culpable, but the entire notion of applets.
Ignition 8.X versions ship with their own Java distribution (an up-to-date patch release of Java 11 at time of Ignition release). This Java distribution isn’t “installed” onto the OS of the gateway, Vision clients, designers, or Perspective sessions in any way; it’s just a flat series of files made available to the parts of Ignition that need it.
I have 2 clients who are asking if Ignition is impacted by Zero-Day RCE Vulnerability. I was able to provide them IA’s official response in regards to the Log4J and this satisfied their IT department. Do you have any official or un-official comments if Ignition is impacted?
This isn't specific enough to answer your question.
This is fine, but they may have been asking about the more recent one involving Spring Framework.
In either case Ignition is not impacted.
I still love GE's attempt at discrediting Java being used in SCADA products. Labelled 'Java-Based HMI/SCADA: Is It Worth the Risk?' I think they have since pulled it, but certainly a good read.
Applied to Ignition, it's laughable. Applied to Honeywell's Niagara/JACE products, it is a serious concern. Last time I touched the latter, I had go way back in time in a VM to run the corresponding tools.
Also (now) Rockwell's Mach2, which is their Niagara-based "MES" software for Plex ERP. Plex has been on our facility for a couple of years and Mach2 is still running under Java 8 and using OPC-DA.
Oof, I might need to pick your brain. I am going to be putting half a dozen Opto22 EPIC controllers with Ignition Edge onboard to poll tags from Honeywell Niagara/JACE stuff here soon. Any hesitations or insights?
It was a communication nightmare. Use the BACnet/IP driver if you can.
Ok, that makes me feel better. They are already using BACnet/IP to their existing Niagara HMI. I am replacing it with Ignition. So, hopefully we don't run into too many issues. We are just in the investigation stage.
I suppose at least with Java you have a client facing measure of if a codebase is being maintained :slight_smile:
I know a few SCADA systems that have basically flat lined with the bare minimum of maintenance updates done to them.
