hey, localhost: 8088 isnt working.i get this in the wrap log.
Failed to parse the version of Java. Resolving to the lowest supported version (1.4).
STATUS | wrapper | 2020/01/03 16:18:10 | Launching a JVM…
INFO | jvm 1 | 2020/01/03 16:18:10 | #
INFO | jvm 1 | 2020/01/03 16:18:10 | # A fatal error has been detected by the Java Runtime Environment:
INFO | jvm 1 | 2020/01/03 16:18:10 | # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff9fe1ab9bd, pid=1456, tid=5440
INFO | jvm 1 | 2020/01/03 16:18:10 | # JRE version: (11.0.4+11) (build )
INFO | jvm 1 | 2020/01/03 16:18:10 | # Java VM: OpenJDK 64-Bit Server VM (11.0.4+11-LTS, mixed mode, sharing, tiered, unknown gc, windows-amd64)
INFO | jvm 1 | 2020/01/03 16:18:10 | # Problematic frame:
INFO | jvm 1 | 2020/01/03 16:18:10 | # V [jvm.dll+0x3eb9bd]
INFO | jvm 1 | 2020/01/03 16:18:10 | # No core dump will be written. Minidumps are not enabled by default on client versions of Windows
INFO | jvm 1 | 2020/01/03 16:18:10 | # An error report file with more information is saved as:
INFO | jvm 1 | 2020/01/03 16:18:10 | # C:\Program Files\Inductive Automation\Ignition\hs_err_pid1456.log
INFO | jvm 1 | 2020/01/03 16:18:10 | # If you would like to submit a bug report, please visit:
INFO | jvm 1 | 2020/01/03 16:18:10 | # http://www.azulsystems.com/support/
just update java or?
