Java error
Has anyone seen this java authentication error? The problem doesn’t go away with a good user name, password and domain value. I’m using IE9.
What are you doing when you get this message?
It is when I launch a client connection to the server.
Do you have some sort of startup scripts that are trying to access remote/mapped drives somewhere else on the network? I've seen this happen in those cases and one of the solutions was having the Ignition service run as a user that had the permissions to access the remote drive they were attempting to access.
I’m using mapped drives and it makes since to me that it could be a permission issue. I’ll look into it.
