I have a script that downloads a file from a ftp site, unzips the file, writes the unzipped contents to a temp file, I then read the temp file line by line and delimit the data to write to another temp csv file. I then call a stored procedure using the csv file.
my problem is the file has grown over the years and i am receiving a java heap space error. i have increased the project to 2GB and the unzipped file has grown to ~147MB.
I can watch the task manager and see the memory increase for java.exe and never gets deallocated as the script progresses.
Is there a file I am not closing or a way for me to deallocated memory as my script is down with files? or is there a better way for me to achieve what I am doing?
the script throws an error on this line csvAsBytes = system.file.readFileAsBytes(csvFile)
from ftplib import FTP
import system
###Get gz file through FTP
ftp = FTP()# connect to host, default port
ftp.connect('ftpurl',21)
ftp.login('username','password')
filename = system.file.getTempFile("gz") #create temp file
ftpFile = open(filename,'wb')
try:
ftp.retrbinary('FILENAME.gz', ftpFile.write) #download file and write to tempfile
except Exception:
def fileMissing():
import system
system.gui.warningBox("The History File is missing from the FTP site.")
system.util.invokeLater(fileMissing)
print "Error in downloading the remote file."
else:
def successfulDownload():
import system
system.gui.messageBox("Successful download!")
system.util.invokeLater(successfulDownload)
print "Successful download!"
ftpFile.close()
ftp.close()
print "ftp closed"
###extract the contents of the gz file
import java
import org.python.core
import gzip
import java.lang.StringBuffer as SB
gzipFile = gzip.open(filename) #open read-binary file f with name fn
contents = gzipFile.read()
gzipFile.close()
print "file unzipped"
###Put contents of gz file in temporary file
newFilename = system.file.getTempFile("txt")
print "created temp file for unzipped content"
system.file.writeFile(newFilename, contents)
contents = None
print "wrote unzipped content to temp file"
fn = newFilename
text_file = open(fn, "r")
lines = text_file.readlines()
text_file.close()
print "read lines from temp file"
csvList = []
for line in lines:
line2 = line.strip().replace("\"","").split(",")
if(line2[0] == "DETAIL"):
toStr = ",".join(line2)
csvList.append(toStr+"\n")
lines = None
print "put lines in list"
csvFile = system.file.getTempFile("txt")
print "created temp file for escaped csv file"
csvWriteFile = open(csvFile, 'w')
for csvLine in csvList:
csvWriteFile.write(csvLine)
print "wrote csv data to temp file"
csvWriteFile.close()
print csvFile
print "converted csv file to bytes"
system.file.writeFile("filepath",csvAsBytes)
print "put csv as bytes file on server"
call = system.db.createSProcCall(event.source.parent.databaseName+"StoredProcedure")
system.db.execSProcCall(call)
print "called stored procedure"
