Hi everybody.
When I try to save a report, no matter the format, from a client, the following error is prompted:
java.lang.OutOfMemoryError: java.lang.OutOfMemoryError: Java heap space
I’ve seen that after rebooting the server it works, however once I save it the first time, the RAM memory in use rises to about 6 GB and it remains occupied all the time.
The memory I’ve allocated for Java is:
Initial Java Heap Size (in MB)
wrapper.java.initmemory=2048
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=12288
With regard to the client, I have:
Initial 128 MB
Max. 4096 MB
Java Version:1.8.0_191-b12
Ignition version: 7.9.10
Any ideas?
The ignition system is running into a virtual machine (VMWARE), may be the problem?
I have another problem, when i try to put my report in the reportviewer, the designer eviroment lock, i see the CPU around the 100% by the Java Web launcher process. I don´t understand because the same report in the designer report scope works well.
Thank you very much
