Java Heap Space Out of Memory
I am trying to pull alarm properties using the browseTagsSimple Funciton.
I keep getting the Java Heap Space out of memory error.
Here is the code below.
Is there a way to stop the error?
Allow Ignition to use more memory. If this error is in the gateway, update ignition.conf and restart the gateway. If in the designer, adjust Configuration => Gateway Settings => Settings => Web-Launch Settings => Designer Memory. In the client, adjust the memory settings for the affected project.
