Hi all,
I have a button which calls a GW script to collect data from Sepasoft T&T module to prepare a dataset which is returned and bound to a power table but I got the next error. The dataset columns number is dynamic depending of the variables selected on the screen before triggering the button.
The dataset is correctly created and returned to the table but I see the error on the console log.
What could I be doing wrong? Thanks
Exception in thread “AWT-EventQueue-1” java.lang.ArrayIndexOutOfBoundsException: 1 >= 0
at java.util.Vector.elementAt(Vector.java:479)
at javax.swing.table.DefaultTableColumnModel.getColumn(DefaultTableColumnModel.java:294)
at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.a(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paint(Unknown Source)
at com.jidesoft.plaf.basic.BasicCellSpanTableUIDelegate.paint(Unknown Source)
at com.jidesoft.plaf.basic.BasicCellSpanTableUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
at javax.swing.JComponent.paintComponent(JComponent.java:780)
at com.jidesoft.grid.CellStyleTable.paintComponent(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$4.paintComponent(VisionAdvancedTable.java:259)
at javax.swing.JComponent.paint(JComponent.java:1056)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5210)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
at javax.swing.JComponent._paintImmediately(JComponent.java:5158)
at javax.swing.JComponent.paintImmediately(JComponent.java:4969)
at javax.swing.RepaintManager$4.run(RepaintManager.java:831)
at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
