java.lang.ClassCastException: Cannot coerce value '-1' into
I see this error usually once when I open the first window in my project. I have searched my project and cannot find any occurrence where I might have a color value of ‘-1’. Any ideas as to why this error occurs would be appreciated:
WARN [SimpleBoundTagAdapter-AWT-EventQueue-0] Cannot coerce value ‘-1’ into type: class java.awt.Color
java.lang.ClassCastException: Cannot coerce value ‘-1’ into type: class java.awt.Color
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1063)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:216)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.setQValue(SimpleBoundTagAdapter.java:233)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:256)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:486)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:475)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$TagChangeListenerProxy.tagChanged(DatasourceTagManager.java:1031)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.subscribe(DatasourceTagManager.java:287)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.subscribe(ClientTagManagerImpl.java:364)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.startup(SimpleBoundTagAdapter.java:140)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:312)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:269)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1571)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:889)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:417)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:606)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:352)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:341)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:455)
at org.python.core.PyObject.call(PyObject.java:387)
at org.python.core.PyObject.call(PyObject.java:391)
at org.python.pycode._pyx3.f$0(event:actionPerformed:7)
at org.python.pycode._pyx3.call_function(event:actionPerformed)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:548)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy16.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
Do you have any color properties bound to a tag?
