I am new to Ignition module development. I am trying to create some tags and then publish the tag values to AWS CloudWatch using AWS JDK.
This is the link of my project.
I am using “com.amazonaws.services.cloudwatch.model.Dimension” to create Dimension. But when I installed the module to Ignition platform, there is an ERROR:
Caused by: java.lang.ClassNotFoundException: com.amazonaws.services.cloudwatch.model.Dimension
Full ERROR:
java.lang.NoClassDefFoundError: com/amazonaws/services/cloudwatch/model/Dimension
at com.inductiveautomation.ignition.examples.mtp.ManagedProviderGatewayHook.readAndPublishTags(ManagedProviderGatewayHook.java:192)
at com.inductiveautomation.ignition.examples.mtp.ManagedProviderGatewayHook.startup(ManagedProviderGatewayHook.java:128)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2386)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1200)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$2.call(ModuleManagerImpl.java:737)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:922)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:700)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1893)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1842)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:912)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:984)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:37)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.loadClass(ModuleClassLoader.java:85)
... 19 common frames omitted
I think the reason maybe the dependency version. But I tried several version of com.amazonaws. The error still comes out.
The SDK is JAVA 11,
