We’re working on building a module that will expose some web services to allow some external control over Ignition. When the Endpoint gets published, it’s throwing a TypeNotPresentException on the interface defined in the Common project. If I add the code to publish the same endpoint to a regular main() method and fire it up locally, it works just fine, so I’m thinking it has to do with the way we’ve built the module. Below is the module definition and the stack trace for the exception. The hook is in the Cell jar, the IProductionOrder is in the Common jar.
Note: For the sake of simplicity, I’ve reduced all the web service hosting down to just Endpoint.publish(“http://localhost:8080/wsServerExample”, new IgnitionCellTierInterface()); It does work in a static void main() method, but does not within AbstractGatewayModuleHook.startup();
[code]<?xml version="1.0" encoding="UTF-8"?>
company-project-cell
Project Cell Module
Description
0.0.0.57-beta1205413474
7.3.0
3
true
<jar scope="G">company-project-common.jar</jar>
<jar scope="G">company-project-cell.jar</jar>
<!-- Tell the Gateway and/or Designer where to find the hooks -->
<hook scope="G">com.company.project.cell.ignition.IgnitionCellTier</hook>
</module>
[/code]
java.lang.TypeNotPresentException: Type com.company.project.common.data.models.IProductionOrder not present
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:98)
at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:107)
at sun.reflect.generics.tree.ClassTypeSignature.accept(ClassTypeSignature.java:31)
at sun.reflect.generics.visitor.Reifier.reifyTypeArguments(Reifier.java:50)
at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:120)
at sun.reflect.generics.repository.FieldRepository.getGenericType(FieldRepository.java:67)
at java.lang.reflect.Field.getGenericType(Field.java:223)
at com.sun.xml.internal.bind.v2.model.nav.ReflectionNavigator.getFieldType(ReflectionNavigator.java:262)
at com.sun.xml.internal.bind.v2.model.nav.ReflectionNavigator.getFieldType(ReflectionNavigator.java:47)
at com.sun.xml.internal.bind.v2.model.impl.FieldPropertySeed.getRawType(FieldPropertySeed.java:63)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeClassInfoImpl$RuntimePropertySeed.getRawType(RuntimeClassInfoImpl.java:304)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeClassInfoImpl$RuntimePropertySeed.getRawType(RuntimeClassInfoImpl.java:278)
at com.sun.xml.internal.bind.v2.model.impl.PropertyInfoImpl.<init>(PropertyInfoImpl.java:108)
at com.sun.xml.internal.bind.v2.model.impl.ERPropertyInfoImpl.<init>(ERPropertyInfoImpl.java:42)
at com.sun.xml.internal.bind.v2.model.impl.ElementPropertyInfoImpl.<init>(ElementPropertyInfoImpl.java:85)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeElementPropertyInfoImpl.<init>(RuntimeElementPropertyInfoImpl.java:48)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeClassInfoImpl.createElementProperty(RuntimeClassInfoImpl.java:154)
at com.sun.xml.internal.bind.v2.model.impl.ClassInfoImpl.addProperty(ClassInfoImpl.java:857)
at com.sun.xml.internal.bind.v2.model.impl.ClassInfoImpl.findFieldProperties(ClassInfoImpl.java:387)
at com.sun.xml.internal.bind.v2.model.impl.ClassInfoImpl.getProperties(ClassInfoImpl.java:290)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeClassInfoImpl.getProperties(RuntimeClassInfoImpl.java:165)
at com.sun.xml.internal.bind.v2.model.impl.ModelBuilder.getClassInfo(ModelBuilder.java:232)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:89)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:70)
at com.sun.xml.internal.bind.v2.model.impl.ModelBuilder.getClassInfo(ModelBuilder.java:198)
at com.sun.xml.internal.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:84)
at com.sun.xml.internal.bind.v2.model.impl.ModelBuilder.getTypeInfo(ModelBuilder.java:304)
at com.sun.xml.internal.bind.v2.model.impl.ModelBuilder.getTypeInfo(ModelBuilder.java:319)
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(JAXBContextImpl.java:430)
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:277)
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1100)
at com.sun.xml.internal.bind.v2.ContextFactory.createContext(ContextFactory.java:143)
at com.sun.xml.internal.bind.api.JAXBRIContext.newInstance(JAXBRIContext.java:95)
at com.sun.xml.internal.ws.developer.JAXBContextFactory$1.createJAXBContext(JAXBContextFactory.java:97)
at com.sun.xml.internal.ws.model.AbstractSEIModelImpl$1.run(AbstractSEIModelImpl.java:148)
at com.sun.xml.internal.ws.model.AbstractSEIModelImpl$1.run(AbstractSEIModelImpl.java:140)
at com.sun.xml.internal.ws.model.AbstractSEIModelImpl.createJAXBContext(AbstractSEIModelImpl.java:140)
at com.sun.xml.internal.ws.model.AbstractSEIModelImpl.postProcess(AbstractSEIModelImpl.java:83)
at com.sun.xml.internal.ws.model.RuntimeModeler.buildRuntimeModel(RuntimeModeler.java:244)
at com.sun.xml.internal.ws.server.EndpointFactory.createSEIModel(EndpointFactory.java:312)
at com.sun.xml.internal.ws.server.EndpointFactory.createEndpoint(EndpointFactory.java:178)
at com.sun.xml.internal.ws.api.server.WSEndpoint.create(WSEndpoint.java:456)
at com.sun.xml.internal.ws.api.server.WSEndpoint.create(WSEndpoint.java:475)
at com.sun.xml.internal.ws.transport.http.server.EndpointImpl.createEndpoint(EndpointImpl.java:213)
at com.sun.xml.internal.ws.transport.http.server.EndpointImpl.publish(EndpointImpl.java:143)
at com.sun.xml.internal.ws.spi.ProviderImpl.createAndPublishEndpoint(ProviderImpl.java:102)
at javax.xml.ws.Endpoint.publish(Endpoint.java:170)
at com.company.project.cell.ignition.IgnitionCellTier.startup(IgnitionCellTier.java:86)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:1994)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1335)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$3.call(ModuleManagerImpl.java:888)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:1017)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:868)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.access$1400(ModuleManagerImpl.java:109)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1636)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1576)
at com.inductiveautomation.ignition.gateway.cluster.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:619)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:640)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:98)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:207)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException: com.company.project.common.data.models.IProductionOrder
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:95)
... 70 more
E: Edited to put in correct stack trace, other one was from a previous test and not the latest.
