Hello everyone,
We are currently experiencing frequent support issues from two separate but related issues with regards to our FactoryPMI launch certificates.
Issue #1 - “The digital signature was generated with a trusted certificate but has expired”
Our web-launched software (the FactoryPMI Client and the FactoryPMI Designer) must be signed in order to launch. The certificate that we have been shipping with for the past two years expired on August 9th. While this doesn’t prevent the application from launching, you may be presented with an extra unfriendly warning when launching an client. Unfortunately there is no mechanism for us to update a certificate that is already out “in the wild”. You will have to upgrade to make this popup go away.
FactoryPMI 3.3.3 which will be released later today contains our new certificate. We apologize for any inconvenience this may have caused. Please note that you will also need to update your plugins, if you have any.
Issue #2 - “Unable to launch the application. JAR resources in JNLP file are not signed by same certificate.”
This is an issue that we have been seeing for a few weeks with some regularity. This was caused by a backwards incompatibility in the way Java 6 update 14 interprets signed *.jar files. The resolution for this problem is to update all of your plugins (Reporting Plugin, ActiveX Plugin) to the new versions which are signed in a way that the newer version of Java accepts.
