Java Launch issues
This is a new installation.
Java Version 7U25
Ignition Version 7.6.4
Window Server 2012
Java is blocking the starting of the Designer.
The attached window pops up.
The More Information button shows the following data:
java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: java.io.IOException: extra data given to DerValue constructor
at com.sun.deploy.security.RevocationChecker.checkOCSP(Unknown Source)
at com.sun.deploy.security.RevocationChecker.check(Unknown Source)
at com.sun.deploy.security.TrustDecider.checkRevocationStatus(Unknown Source)
at com.sun.deploy.security.TrustDecider.getValidationState(Unknown Source)
at com.sun.deploy.security.TrustDecider.validateChain(Unknown Source)
at com.sun.deploy.security.TrustDecider.isAllPermissionGranted(Unknown Source)
at com.sun.javaws.security.AppPolicy.grantUnrestrictedAccess(Unknown Source)
at com.sun.javaws.security.JNLPSignedResourcesHelper.checkSignedResourcesHelper(Unknown Source)
at com.sun.javaws.security.JNLPSignedResourcesHelper.checkSignedResources(Unknown Source)
at com.sun.javaws.Launcher.prepareResources(Unknown Source)
at com.sun.javaws.Launcher.prepareAllResources(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main.access$000(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Suppressed: com.sun.deploy.security.RevocationChecker$StatusUnknownException
at com.sun.deploy.security.RevocationChecker.checkCRLs(Unknown Source)
… 18 more
Caused by: java.security.cert.CertPathValidatorException: java.io.IOException: extra data given to DerValue constructor
at sun.security.provider.certpath.OCSP.check(Unknown Source)
… 19 more
Caused by: java.io.IOException: extra data given to DerValue constructor
at sun.security.util.DerValue.init(Unknown Source)
at sun.security.util.DerValue.(Unknown Source)
at sun.security.provider.certpath.OCSPResponse.(Unknown Source)
… 22 more
Any suggestions?
Found this on the Oracle website. Needed to change the “Check for certificate revocation using” from
“Both CRLs and OCSP” to “Certificate Revocation Lists (CRLs)”
My Ignition server does not have Internet access.
