I have a project that is on many PC’s. We have direct links on the desktops to the gateway for each project. I had to increase the java memory available from 256k to 512k, which I done in designer and saved it. I can close and re-boot the PC’s and the clients do not download these new memory settings. The only way I can get them to the client is to run this:
“javaws -uninstall” and then to delete the folder “.ignition” from the user profile.
There has to be a way to push this to all, yes the project is set to push. Is there something within the project that can be changed which would cause a full download again?
