We have an Ignition (8.1.18) server where every two days a buffer overflow exception is happening. Once the buffer overflow occures, all execution of scripts are halted. Simply editing a script and saving it (or using EAM to push the tags/project), seems to temporarily resolve the problem. Has anyone a suggestion how to find the cause for this? Traceback (most recent call last):
File "<TimerScript:RSS_new/update_group_command_schedule @1,000ms >", line 2, in
File "module:group_command", line 495, in update_group_command_schedule
java.nio.BufferOverflowException
at java.base/java.nio.HeapByteBuffer.put(Unknown Source)
at org.python.core.io.BufferedWriter.write(BufferedWriter.java:41)
at org.python.core.io.BinaryIOWrapper.write(BinaryIOWrapper.java:118)
at org.python.core.io.TextIOWrapper.write(TextIOWrapper.java:260)
at org.python.core.PyFile.file_write(PyFile.java:456)
at org.python.core.PyFile.write(PyFile.java:460)
at org.python.core.StdoutWrapper.printToFile(StdoutWrapper.java:117)
at org.python.core.StdoutWrapper.print(StdoutWrapper.java:186)
at org.python.core.StdoutWrapper.println(StdoutWrapper.java:272)
at org.python.core.Py.println(Py.java:1905)
at org.python.pycode._pyx26915.update_group_command_schedule$8(module:group_command:497)
at org.python.pycode._pyx26915.call_function(module:group_command)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:119)
at org.python.core.PyFunction.call(PyFunction.java:406)
at org.python.pycode._pyx62.f$0(<TimerScript:RSS_new/update_group_command_schedule @1,000ms >:2)
at org.python.pycode._pyx62.call_function(<TimerScript:RSS_new/update_group_command_schedule @1,000ms >)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:796)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:819)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:748)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:800)
at com.inductiveautomation.ignition.common.script.TimerScriptTask.run(TimerScriptTask.java:90)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
java.nio.BufferOverflowException: java.nio.BufferOverflowException
8.1.18 (b2022061518)
Azul Systems, Inc. 11.0.15
