I will be the first to admit I dont know much about if any about JAVA. Attached is the code I am using on a button.
[code]y=0
z=0
#from ftplib import FTP
import sys
import fpmi
sys.add_package(“org.python.core”)
from java.lang import Runnable,Thread
machines = fpmi.db.runQuery(“SELECT mach_num FROM progmode1 WHERE online = 0 and mach_num<10 order by mach_num”)
y = len(machines)
fpmi.tag.writeToTag("[]availrec",y)
#machines = fpmi.db.runQuery(“SELECT mach_num FROM interim WHERE mach_sel = 1 AND shift = 1”)
#machines = event.source.parent.machine
class FTPDownload(Runnable):
def __init__(self):
self.m=[]
def addMachine(self, machineId):
self.m.append(machineId)
def run(self):
for i in self.m:
k=i+10
string = '10.0.0.'+str(k)
filename = 'setup.csv'
filename2 = 'emp2.csv'
try:
print "Connecting to %s"%string
[b]1. ------>[/b]
ftp = FTP(string)
print "Connected to %s, Logging in..."%string
ftp.login('david','bigbrother')
print "Uploading to %s"%string
ftp.set_pasv(0)
ftp.delete(filename)
ftp.delete(filename2)
file = open(filename, 'rb')
print string,filename
ftp.storbinary('STOR '+filename,file)
file.close()
file2 = open(filename2, 'rb')
print string,filename2
ftp.storbinary('STOR '+filename2,file2)
file2.close()
ftp.quit()
print "Done ",i
except Exception, e:
print "HEY STUPID LOOK HERE IT FAILED. HERE IS WHY: %s. ("%string,e,")"
z=z+1
2. ------> fpmi.tag.writeToTag("[]fault",z)
Create 5 download objects
downloaders = []
for x in range(4):
downloaders.append(FTPDownload())
fpmi.tag.writeToTag("[]wroterec",x)
Round-robin assign machine ids to the downloaders
x=0
for row in machines:
m = row[0]
downloaders[x].addMachine(m)
x = (x+1)%len(downloaders)
Start a thread for each of the 5 downloaders
for downloader in downloaders:
Thread(downloader).start()
[/code]
What I am trying to do is have a self incrementing counter for each time it successfully connect and one for each time it faults. If you look at #1 above I had the following lines:
p=p+1
fpmi.tag.writeToTag("[]wrote",p)
But it kept comming up with NAME ERROR: P error message. I did try different letter but all came back with same error message. I get the same type of message but with the letter Z if an error occurs.
In the section CREATE 5 Downloader objects I tried placing:
fpmi.tag.writeToTag("[]wrote",x)
Here I got a value back but it appears that it only loops thru this routine 3 times.
So where can I place these incremental counters so that they will work properly in this script? Like I said I want the one to count each time there has been success logging into a ftp and one to count each time there has been a failure and then I want to be able to use these on my screen to display.
because I spelled it wrong. Oops!
