Ok, I’m porting some code over from java, and again I’m haing a problem figuring out what to pass in for parameters. In the following code, I get the “readAsBytes() takes at least 2 arguments (1 given)” error. How can I tell what it’s looking for?
from java.lang import Byte
from java.io import FileInputStream
import jarray
import java.net
def readAsBytes(self,file):
print 'ok'
url = java.net.URL("http://localhost:8088/Import/Test.txt")
B=readAsBytes(url)
What are you wanting the code to do? If you want to read the file as an array of bytes, there is an Ignition function to do this - system.file.readFileAsBytes(filepath).
Nope, I wasn’t aware of that. That just might do the trick. But, the point still stands- what is this looking for? I think it’s looking for a File object, and I tried instantiating one by passing in various flavors of java.io.newInstance(), but no-go. Just want to understand this a little better. (I’ve added a line of code in the function, and the rest will work if it gets past the File object).
import jarray
import java.net
f = File(file)
B=readAsBytes(url)
Yes it will because the function does not have the Java File imported. You need to place the imports inside the function:[code]from java.lang import Byte
import jarray
import java.net
def readAsBytes(file):
f = File(file)
