java.sql.Timestamp and datetime.datime
Hi all,
I created a memory tag in Ignition which record the datetime of a particular event.
In a component I read the value of the datetime in the memory tag and I compare it with datetime.datatime.now() simple by:
lastDatetime = system.tag.read(lastDatetimeTagPath).value td = datetime.datetime.now() - lastDatetime
to check how long the time has lasted since the event and Ignition gives run time error.
After my further check, I realized that the run time error is caused by the script line:
because the type of datetime.datetime.now() is “datetime.datime” while lastDatetime is “java.sql.Timestamp”
My question is how can we get time difference between datetime.datetime and java.sql.Timestamp object in Ignition?
Or else, is there a way to convert java.sql.Timestamp object to datetime.datetime object?
Thank you!
Hi all,
I managed to convert java.sql.Timestamp to datetime.datetime by:
dtObj = datetime.datetime(tsObj.year + 1900, tsObj.month + 1, tsObj.date, tsObj.getHours(), tsObj.getMinutes(), tsObj.getSeconds())
I am not sure if this is the best way to do it, since I lost the millisecond precision here.
Is there any conversion way which retain the millisecond precision?
Rather than using datetime, the Scripting / Python / Python in Ignition / Working with Different Datatypes section of the manual points out it is easier to use the Java java.util.Date class.
The following script should let you do what you want:
# Use the java Date class, the same as a memory tag of type DateTime.
from java.util import Date
# This returns the current time.
now = Date()
# Read the value of the memory tag.
lastDatetime = system.tag.read('New Tag').value
# The getTime() function returns the DateTime in milliseconds, so you
# can subtract one from the other. The result is in milliseconds.
tdMillis = now.getTime() - lastDatetime.getTime()
# If you wish you can create another Date object from the millisecond value.
td = Date(tdMillis)
# The dateFormat command allows you to format the Date object any way you want.
print tdMillis, system.db.dateFormat(td, "mm:ss.S")
Hi AlThePal,
Thanks for the reply. Yes, I found working with Date() is easier. :slight_smile:
