Javascript inject in Perspective... have fun
Soo i'll just link this here...
You can do whatever with it, but its not really gonna be clean or easy xD Have fun :man_mage:
WARNING
Dont let userinput enter in here
You magician! :magic_wand::mage:If I knew any JavaScript I would certainly try this out, haha, but this seems VERY cool! It would be cool if you could write it back to the view... :sweat_smile:
At first sight i found the page context and session context. But the page context isn't really the same as the view... There is a function findView(resourcePath: string, mountPath: string) in it though... So i bet you could find it... It would require a lot more javascript though, so probably not idea to try and code that inside a markdown string xD
Here ya go xd
Gonna try to keep this topic updated with all my cool injectings :stuck_out_tongue:
Version 8.1.22 svg clicker :wink:
This seems like something geared more toward Ignition Exchange, as opposed to sporadic forum postings.
Let's say... keep it to one thread, instead of creating new ones.
I am surprised that the JS Injection hack would even be approved into the exchange! lol
Shhhh! :shushing_face: :grimacing:
We might find this thread just...
disappear
WARNING
Edited the top for this too.
Have you tried to determine if the device running the perspective screen had geolocation functionality and if so were you able to get device location? With something like this: ```
function get_location() {
if (Modernizr.geolocation) {
navigator.geolocation.getCurrentPosition(show_map);
} else {
getCurrentPosition
Navigator.geolocation snippet:
For my use case I would not want a map, just longitude and latitude coordinates.  Would use them to confirm location, then check location against a variable set to confirm the user is in a location that will allow certain on page functionality to become accessible. Purpose is to write a perspective screen to handle hourly employees clock in / out, but only allow if user is on site or within a certain range of the facility they were clocking into. Would need to get the long and lat values to run a comparison. Link above suggests:  ```
function show_map(position) {
  var latitude = position.coords.latitude;
  var longitude = position.coords.longitude;
session settings have geolocation already
https://docs.inductiveautomation.com/display/DOC81/Session+Properties
Anyways this seems weird to use it for checkins...
Dont you need to be on the company ip addres already to enter perspective xd (be in wifi range)
Or are you hosting it online?
In which case this is not very secure
Victor,
Thank you for pointing that out. What do you do for a living? Are you interested in work? I have a couple of Ignition projects I would be interested in hiring someone to create for me.
Roger E. Henley II
VP Engineering & Technology
Whiskey House
rhenley@whiskeyhouse.com
304-932-8706
I haven't found a reliable way to focus a component on View load (tried onStartup events on both the popup View and the input component, as well as on custom prop value change scripts on the input component...), outside of JS.. so here is what I use:
    "type": "ia.display.markdown",
    "version": 0,
    "props": {
      "markdown": {
        "escapeHtml": false
    "meta": {
      "name": "SetFocusById"
    "position": {
      "shrink": 0,
      "basis": 0
    "custom": {
      "domIdToFocus": "setpointInputField"
    "propConfig": {
      "props.source": {
        "binding": {
          "type": "expr",
          "config": {
            "expression": "{this.custom.domIdToFocus}"
          "transforms": [
              "code": "\tcode =  \"<img style='display:none' src='/favicon.ico' onload=\\\"const element = document.getElementById('\" + value + \"');if (element) { element.focus(); }\\\"></img>\"\n\treturn code",
              "type": "script"
JavaScript injection? :face_vomiting:
haha, I know this is a thing and NEED to start using it.. let me try
@bmusson
I've tried this with both blocking and async and no worky. It prints "focusing element" to the console but doesn't actually focus it on launch of the popup (tried same things as above: onStartup scripts and on custom prop script transform and onChange script with a binding just setting it to 1, non-persistent value). Calling the function from a button on the view works though. How would I make it work on load?
def onChange(...):
	function = '''(domId)=>{
		const element = document.getElementById(domId);
		console.log(element)
		if (element){
			console.log('focusing element');
			element.focus();
	system.perspective.runJavaScriptBlocking(function, {'domId': self.custom.domIdToFocus})
I presume the markdown hack works because the markdown component has to load first, presumably along with all the other componnets including the input field to focus, and it adds in the "img" component into the div after these have all loaded, so the onLoad script can then find the focus element and actually focus it. This seems to be the issue with other methods; the component to focus isn't actually loaded and/or displayed when the focus function is called.
Yup, you're exactly right, runJavaScriptAsync won't work for this :confused:
I do have one other option: use the events.target.lifecycle.onMount callback of the Portal component.
The Portal component doesn't have any documentation written yet... but, basically, it allows you to interact with a DOM element and directly insert children.
A side-feature is the events.target.lifecycle functions. Here, you can add functions that will run when the target element loads, unloads, or updates. For example:
# element (DOM ID or arrow function that returns a reference to a node).
TextField
# events.target.lifecycle.onMount
(element) => element.focus()
This is pretty much the same thing as the Markdown component injection version though, just with a little more hand-holding.
Edit:
There is an issue with the Portal component that hasn't been fixed yet; it doesn't listen for DOM changes after the first render. This means the Portal component must load after the target.
Until this issue is fixed, the Portal component doesn't have an advantage over the Markdown injection technique. Once it's fixed, it won't be load order sensitive.
That's pretty cool! I didn't really know what I would use the Portal for when you first released it. The examples you showed like adding alarm decorations to components were cool (nice styling), but I didn't see how it would be applicable at scale e.g. for multiple devices with alarms with different conditions/priority/etc. I'm sure there are some cool use-cases for it though. But really, I wanted to use it purely because of its name :face_with_hand_over_mouth:
Edit: with a module, is it possible to add custom event listeners, e.g. add an onActuallyLoaded handler to run after the component has actually fully loaded and displayed?
Honestly, same :laughing:.
I’ve used the onMount functionality way more than the actual portal feature.
Maybe? Let me mull it over.
That seems to be a commonly requested feature.
My goal has been to make all of Embr’s components have this in the form of the events properties. All of them will have events.dom and events.lifecycle, but some have extras (like the Portal’s target or the chart’s chart lifecycle events).
