JDBC failed after Ignition Upgrade
We have a Test server that mirrors a Production Server. Both have version 8.1.32. I have the latest snowflake-jdbc-3.14.4 installed on both servers and they were making connections to a Snowflake database fine.
But after the Test Server is upgraded to 8.1.36, the db connection was faulted and the driver threw an error:
java.sql.SQLException: Cannot create PoolableConnectionFactory (JDBC driver internal error: exception creating result java.lang.NoClassDefFoundError: Could not initialize class net.snowflake.client.jdbc.internal.apache.arrow.memory.util.MemoryUtil at net.snowflake.client.jdbc.internal.apache.arrow.memory.ArrowBuf.getDirectBuffer(ArrowBuf.java:231).)
Does anyone have this experience?
You'll need to modify ignition.conf and add a line like this:
wrapper.java.additional.7=--add-opens=java.base/java.nio=ALL-UNNAMED
The number after "additional" may be different in your config, it should be the next sequential and unused number in that section.
Yup, that fixed the issue. Thanks.
I recently worked on setting up a connection to snowflake. While working on it, I spent quite some time to figureout the right compatibility between the driver and the snowflake instance + the ignition.conf wrapper setting mentioned here.
Suggestion to the IA team to add this in the section.
Works like a charm. Thank you.
