How can I set antialias for texts in my right-click menu (JMenuItem):
from functools import partial
from javax.swing import JMenuItem
from javax.swing.border import EmptyBorder
from com.inductiveautomation.ignition.client.images import PathIcon
from java.awt import Color
from java.awt import Font
menu = system.gui.createPopupMenu([],[])
font_Size = 18
font = Font("Arial Narrow", Font.BOLD,font_Size)
ico = PathIcon()
ico.path = "checkmark_blue_24.png"
menuitem3 = JMenuItem (menuText3,ico, actionPerformed=partial(project.popmenu.setConveyorManualOFF_ON,objekt=event))
menuitem3.setForeground(Color.BLACK)
#menuitem3.setFont(menuitem3.getFont().deriveFont(fontSize))
#menuitem3.setFont(Font("Arial Narrow", Font.BOLD,font_Size))
menuitem3.setFont(font)
if "Operater" in system.security.getRoles():
menuitem3.setEnabled(True)
else:
menuitem3.setEnabled(False)
menu.add(menuitem3)
All other texts are antialiased, only right-click menu looks terrible…
Oh, this is on Windows 10, with no scaling (100%).
JMenuItems are subclasses of JComponent. Consider further subclassing them and re-implement paintComponent() to turn on the anti-aliasing rendering hint before calling the superclass method.
Exception in thread "AWT-EventQueue-0" Traceback (most recent call last):
File "<module:project.popmenu>", line 9, in paintComponent
AttributeError: 'super' object has no attribute 'paintComponent'
TypeError: super() takes 1-2 arguments (0 given)
I also tried:
super.paintComponent(g)
super(JMenuItem).paintComponent(g)
super(self).paintComponent(g)
and I always get:
AttributeError: type object 'super' has no attribute 'paintComponent'
I suspect that adding the “s” simply makes your method not be called at all, as it isn’t overriding anything that the GUI uses. Consider my original suggestion, but replacing JMenuItem with its parent classes until you find one that works. Possibly JComponent.
Well… replacing JMenuItem with JComponent also doesn’t work…
And I really don’t understand this class stuff…
so I guess there is no antialiasing for me…
paintComponent() is a protected method of JComponent so it can not be called from a subclass.
JMenuItem also inherits from JContainer (because JComponent is a subclass of JContainer) which includes the public method paintComponents which is why when you add the “s” your code does not error, but also does not yeild the expected result.
A way to check this is to run the following script which will return all of the callable attributes and methods of the class:
print dir(JMenuItem)
If you take the time to read all of that, you will find that paintComponent is not listed, but paintComponents is. This is because jython is honoring the Java Accessibility.
So, if you want antialiasing then you will need to paint the component yourself without calling the super. That would be fairly involved, but could be done.
This is wrong. The entire purpose of protected visibility is to allow subclasses access without allowing outside access. This is perhaps why you don't see it listed with dir, because given an instance of a class you can't call protected methods or access protected variables, but you can certainly access or override from a subclass.
There’s a bug within the Jython interpreter. You can use the automatically-created super__ method to directly call the super method; super()should work but doesn’t:
from java.awt import RenderingHints
from java.awt import Toolkit
from java.util import Map
from javax.swing import JMenuItem, JComponent
class antiAliasedJMI(JMenuItem):
def paintComponent(self, g):
g.setRenderingHint(RenderingHints.KEY_RENDERING, RenderingHints.VALUE_RENDER_QUALITY)
g.setRenderingHint(RenderingHints.KEY_ANTIALIASING, RenderingHints.VALUE_ANTIALIAS_ON)
g.setRenderingHint(RenderingHints.KEY_TEXT_ANTIALIASING, RenderingHints.VALUE_TEXT_ANTIALIAS_ON)
g.setRenderingHint(RenderingHints.KEY_FRACTIONALMETRICS, RenderingHints.VALUE_FRACTIONALMETRICS_ON)
self.super__paintComponent(g)
a = antiAliasedJMI("text", None, action=partial(system.gui.messageBox, "title", "message"))
menu.add(a)
menu.show(event)
Also, I don’t think you need to override init, which makes it all feel a little less “magic”.
As much as I would love to claim I had just mixed them up, I won’t.
I wrote what I thought to be correct. However, I will take it as the learning it is, as I have had plenty of occasions where I needed to call protected super methods, and now I know the ‘trick’ to accomplishing that.
I do dislike being wrong, but it really is one of the best ways to learn.
