Good day all. Can you join 2 query tags? I know I can do it in the named query with a combinedDataset python code, only issue with this is the query take too long to do what I want in a timely manner. So, I have the query into a tag rather than a Named Query.
There's no native way to join (SQL-like I presume) datasets. You need jython. Consider an expression tag that hands off to runScript with the two other tags as arguments.
Thats a good idea. Ill try to put something together and probably (more than likely) ask for input. LOL
So here is how I was doing it previously (cant do it like this anymore due to IT restrictions):
styleAccountedFor = {'backgroundColor': "green"}
MusterCall = value #system.db.runNamedQuery('MusterCall')
SM_Salary = system.db.runNamedQuery('SM_Salary')
combinedDataset = system.dataset.appendDataset(MusterCall,SM_Salary)
combinedData = system.dataset.toPyDataSet(combinedDataset)
headers = system.dataset.getColumnHeaders(combinedData)
checkedInData = (self.getSibling("Table_0").props.data)
accountedBadgeNum = [B['Badge_Num'] for B in checkedInData]
pyObj = []
for row in combinedData:
pyDict = {}
pyValueDict = {headers[i]: row[i] for i in range(len(row))}
if pyValueDict['ShawEmployeeID'] in accountedBadgeNum:
pyValueDict['isAccountedFor'] = True
pyDict['value'] = pyValueDict
pyDict["style"] = styleAccountedFor
else:
pyValueDict['isAccountedFor'] = False
pyObj.append(pyDict)
return pyObj
Here is how im tring to make an expression tag using the runScript:
runScript("MusterCall = system.db.runNamedQuery('MusterCall') SM_Salary = system.db.runNamedQuery('SM_Salary') combinedDataset = system.dataset.appendDataset(MusterCall,SM_Salary) combinedData = system.dataset.toPyDataSet(combinedDataset)")
Am I remotely close?
No, with runScript, you must choose between a one-line jython expression that returns your value, possibly involving scripts from your gateway scripting module, or a simple function name from your gateway scripting project, with arguments after the polling interval passed to that function.
So, something like this in the expression:
runScript("myScript.myFunction", 0, {[.]SomeTag}, {[.]SomeOtherTag})
That function would do the rest of the work.
SO I have something that works for me:
I have the Name query that took too long as a query tag and appended my other Named Query onto it like this:
MusterCall = value
pyObj = []
pyDict = {}
else:
return pyObj
whole thing looks like this:
It mostly does what I want to.
My issue now is that the style is being applied very slow, as in lagging way behind. How can I speed that up? The style is applied when LH table sees the same data in RH table:
You could try with a query tag for each query and use an expression structure binding, instead of making one of the query in the transform.
PS: code style is good, but please get rid of all the extra whitespaces, it's triggering my OCD :X
(also, the double quotes on line 22)
edit:
Wait, where is that binding ? Is that on the table ?
For anyone else wanting a solution I came up with a message handler that does the refreshBinding on the LH table when the RH tables data changes (change script). That way when my INSERT INTO python code populates the RH table a message tells the LH table to refresh its binding and and the style get applied.
