JSerialCom No Module Named fazecast
Am I missing something basic
I have the following script and I keep getting a “No Module named fazecast” error
from com.fazecast.jSerialComm import SerialPort
ports = list(SerialPort.getCommPorts())
Are you sure that the fazecast library is included in Ignition's base java library? Or if you are supplying the library .jar file, has it been placed in the correct location, and the gateway and designer have been restarted?
What version of Ignition are you using?
