Hello everyone,
When importing a json file containing OPC tags, we noticed the following behaviour:
- if the OPC device is online, then the tags are good
- if the OPC device is not connected, then the tags show "Error_Configuration" when imported
Note that for all the devices have been configured in the gateway's "Device Connections" (They are ControlLogix PLCs in this case).
Is this a feature of Ignition, showing "Error_Configuration" for devices that have never been connected to the Ignition server before? Or is it some problem with our configuration?
Thanks in advance
