JSON Object Does Not Insert Into SQLite Table Correctly
In an event script on a view component, I have an INSERT query that I run with system.db.runPrepUpdate. One of my columns in the table I'm inserting rows into is a BLOB type, and I would like to store JSON objects in it.
My trouble is that when I run the query, this blob column does not contain the JSON object I pass as an argument into the runPrepUpdate function. Instead, it contains some odd value that looks like an array with a serialized value in it:
Additionally, whenever I run a SELECT query on this column, the serialized value changes.
I am not sure what is causing this and how to prevent it. Any ideas?
That's the stringified form of a byte array in java. It appears different because java makes a new array to hold the content on every query, and the "address" is part of the stringification.
Don't stringify blobs.
Consider not using a BLOB column.
Changing the column type to TEXT did the trick, thanks for the advice.
What's odd to me is that I'm also converting an array to a JSON object and inserting it into the same table (different BLOB column), and the JSONed array is stored as inserted.
Not sure why there's a difference between these two cases besides the fact that one JSON object was originally an array and the other was an object/dictionary.
