JSON schema for view.json
Hi Everyone,
Can anyone point me to the JSON schema for perspective’s view.json?
I am looking to dynamically generate views and would like to have some kind of enforcement to prevent broken views.
I see this post that gives the schema for SVG component but not the structure of view.json itself.
Thanks,
Noah B
What is your end goal here, what problem are you attempting to solve or bypass?
Ignition's strength lies in being able to re-use common views via indirect bindings and the like. If you are planning on making X number of pump(or other device) control screens, you are approaching this incorrectly.
Make a common control view, pass needed tagPaths or other information that can be used to build the correct tag paths and indirectly bind needed tags to view custom properties.
Hi Ryan, thanks for your response.
This is exactly what I'm trying to dynamically generate. When a client gives say a csv of required process parameters to show along with other information, I don't want to have to manually configure each binding. Especially when I can feed a program or agent the requirements and the view.json and saves manual configuration.
To address the original question, the JSON schema would simply be a guardrail to make sure whatever is generating the view is valid.
You're talking about view.json of a Perspective View resource on disk?
If so, there is no schema defined for htis.
I still think this is wrong approach, but, I would rather build my standard view in Ignition and then program something to crawl the resulting view/json and adjust the target tag paths/members to what I was provided by the customer, and spit that out as a new view. Less likely to break the view compared to generating from scratch each time.
But at that rate, you are essentially just doing a glorified search and replace.
If you follow a consistent standard with how you organize your tags, you can probably get away with only having to change the tagPath that is passed to embedded views or popups.
Hi Kevin,
That is correct. For the perspective resource on disk.
So the only enforcement is at the perspective component level such as this example? How does perspective validate the view.json then?
view.json is a serialization format that is effectively private because it's an implementation detail.
It's serialized and deserialized with custom GSON serializers. There is no validation. Deserialization will blow up if you screw up the format.
Those schemas in the SDK examples are for a different purpose - they tell the Designer about what properties a component has.
Everything Kevin said is absolutely true, but for what it's worth, here's Claude's attempt to synthesize a schema out of the actual runtime validation, if it's actually useful to you.
I make no claims to the accuracy or usefulness of this.
Schema
  "$schema": "http://json-schema.org/draft-07/schema#",
  "title": "ViewConfig",
  "description": "Perspective view configuration, as serialized by the standard (design-time) GSON adapters.",
  "type": "object",
  "required": ["root"],
  "additionalProperties": false,
  "properties": {
    "root": {
      "$ref": "#/$defs/ComponentConfig"
    "props": {
      "type": "object",
      "description": "View-level properties."
    "custom": {
      "type": "object",
      "description": "View-level custom properties."
    "params": {
      "type": "object",
      "description": "View parameters."
    "events": {
      "$ref": "#/$defs/EventConfig"
    "permissions": {
      "$ref": "#/$defs/PermissionsConfig"
    "propConfig": {
      "$ref": "#/$defs/PropertyConfigCollection"
  "$defs": {
    "ComponentConfig": {
      "type": "object",
      "description": "Configuration for a single Perspective component.",
      "required": ["type"],
      "properties": {
        "type": {
          "type": "string",
          "description": "The component type identifier."
        "version": {
          "type": "integer",
          "description": "Component schema version. Omitted when 0.",
          "minimum": 1
        "props": {
          "type": "object",
          "description": "Component properties."
        "meta": {
          "type": "object",
          "description": "Component metadata."
        "position": {
          "type": "object",
          "description": "Component position/layout properties."
        "custom": {
          "type": "object",
          "description": "Custom properties."
        "propConfig": {
        "events": {
        "scripts": {
          "$ref": "#/$defs/ScriptConfig"
        "children": {
          "type": "array",
          "items": {
    "EventConfig": {
      "type": "object",
      "description": "Event configuration. Keys are event group names (e.g. 'dom', 'component', 'system'), values are objects mapping event names to actions.",
      "additionalProperties": {
        "type": "object",
        "description": "An event group. Keys are event names (e.g. 'onClick', 'onStartup'), values are a single action or an array of actions.",
          "oneOf": [
              "$ref": "#/$defs/ActionConfig"
              "type": "array",
              "items": {
    "ActionConfig": {
      "type": "object",
      "description": "Configuration for a single event action.",
      "required": ["type", "scope"],
      "properties": {
        "type": {
          "type": "string",
          "description": "The action type identifier."
        "scope": {
          "type": "string",
          "enum": ["G", "C"],
          "description": "Action execution scope. G = Gateway, C = Client."
        "config": {
          "type": "object",
          "description": "Action-specific configuration."
        "enabled": {
          "type": "boolean",
          "description": "Only serialized when false (disabled). Absence implies true.",
          "const": false
        "preventDefault": {
          "type": "boolean",
          "description": "Only serialized when true. Absence implies false.",
          "const": true
        "stopPropagation": {
          "type": "boolean",
          "const": true
        "permissions": {
    "PropertyConfigCollection": {
      "type": "object",
      "description": "A map of property path strings to their property configurations.",
        "$ref": "#/$defs/PropertyConfig"
    "PropertyConfig": {
      "type": "object",
      "description": "Configuration for a single property (binding, persistence, access, etc.).",
      "properties": {
        "binding": {
          "$ref": "#/$defs/BindingConfig"
        "persistent": {
          "type": "boolean",
          "description": "Whether the property value is persisted."
        "paramDirection": {
          "type": "string",
          "enum": ["input", "output", "inout"],
          "description": "View parameter direction."
        "onChange": {
          "$ref": "#/$defs/PropertyChangeScriptConfig"
        "access": {
          "type": "string",
          "enum": ["PUBLIC", "PRIVATE", "PROTECTED", "SYSTEM"],
          "description": "Property access level."
    "BindingConfig": {
      "type": "object",
      "description": "Configuration for a property binding.",
      "properties": {
        "type": {
          "type": "string",
          "description": "The binding type identifier."
        "enabled": {
          "type": "boolean",
          "description": "Whether the binding is enabled. Null/absent implies true."
        "overlayOptOut": {
          "type": "boolean",
          "description": "Whether the binding opts out of overlay behavior. Null/absent implies false."
        "previewEnabled": {
          "type": "boolean",
          "description": "Whether the binding is active in preview mode. Null/absent implies true."
        "config": {
          "type": "object",
          "description": "Binding-type-specific configuration."
        "transforms": {
          "type": "array",
          "description": "Ordered list of transform configurations applied to the binding output.",
          "items": {
            "type": "object"
    "ScriptConfig": {
      "type": "object",
      "description": "Script configuration for a component. Serialized with serializeNulls, so all fields are present.",
      "properties": {
        "customMethods": {
          "type": ["array", "null"],
          "items": {
            "$ref": "#/$defs/CustomMethodConfig"
        "messageHandlers": {
          "items": {
            "$ref": "#/$defs/MessageHandlerConfig"
        "extensionFunctions": {
          "items": {
            "$ref": "#/$defs/ExtensionFunctionConfig"
    "CustomMethodConfig": {
      "type": "object",
      "description": "A user-defined scripting method on a component. Serialized with serializeNulls.",
      "properties": {
        "name": {
          "type": ["string", "null"]
        "params": {
          "items": {
            "type": "string"
        "script": {
    "MessageHandlerConfig": {
      "type": "object",
      "description": "Configuration for a message handler script. Serialized with serializeNulls.",
      "properties": {
        "messageType": {
        "script": {
        "sessionScope": {
          "type": "boolean"
        "pageScope": {
          "type": "boolean"
        "viewScope": {
          "type": "boolean"
    "ExtensionFunctionConfig": {
      "type": "object",
      "description": "Configuration for a component extension function. Serialized with serializeNulls.",
      "properties": {
        "name": {
        "script": {
        "enabled": {
          "type": "boolean"
    "PropertyChangeScriptConfig": {
      "type": "object",
      "description": "Script that runs when a property value changes. Serialized with serializeNulls.",
      "properties": {
        "script": {
        "enabled": {
          "type": ["boolean", "null"],
          "description": "Null means true (for serialization efficiency)."
    "PermissionsConfig": {
      "type": "object",
      "description": "Security permissions configuration.",
      "required": ["type", "securityLevels"],
      "properties": {
        "type": {
          "type": "string",
          "enum": ["AllOf", "AnyOf"],
          "description": "How security levels are evaluated."
        "securityLevels": {
          "type": "array",
          "items": {
            "$ref": "#/$defs/SecurityLevelConfig"
    "SecurityLevelConfig": {
      "type": "object",
      "description": "A node in the security level tree. Uses simple mode (no description field).",
      "required": ["name", "children"],
      "properties": {
        "name": {
          "type": "string",
          "description": "The security level name."
        "children": {
          "type": "array",
          "description": "Child security levels.",
          "items": {
Not sure in understand your use case but you may want to check this module out by @bmusson.
It will render a view.json when passed as a parameter.
Json View | Musson Industrial
