Hello everyone,
Here’s my problem. I want the content of a .json file to automatically feed a tag using a scheduled task.
Here is my .json file:
{"timestamp": "2025-09-04T16:16:40+02:00", "topic": "data/moxa-tbedb1004623", "payload": "{"hostname":"moxa-tbedb1004623","ip":"10.228.68.197","lat":43.343553800,"lon":5.364255933,"signal":{"rssi":-68.00,"rsrq":-18.00,"rsrp":-100.00,"snr":13.40},"data":{}}"}
Here is my code in the project library (read_json):
import json
def lireDerniereCoordonnees(file_path = "/var/lib/ignition/data/mqtt_data_json/data_moxa-tbedb1004623.json"):
with open(file_path, "r") as f:
lignes = f.readlines()
print("Nombre de lignes lues :", len(lignes)) # debug
if not lignes:
return None, None
derniere = lignes[-1].strip()
print("Dernière ligne :", derniere) # debug
obj = json.loads(derniere)
payload = json.loads(obj["payload"])
lat = payload.get("lat")
lon = payload.get("lon")
print("Lat/Lon :", lat, lon) # debug
return lat, lon
Here is the content of my scheduled task:
def onScheduledEvent():
import read_json
lat, lon = read_json.lireDerniereCoordonnees()
if lat is not None and lon is not None:
system.tag.writeBlocking(
"[default]MQTT_Tags/SMDB/Edge_Node_tbedb1004623/Centri/Metadata/Latitude_Edge",
"[default]MQTT_Tags/SMDB/Edge_Node_tbedb1004623/Centri/Metadata/Longitude_Edge"
[lat, lon]
However, when I run a test via the Ignition terminal, here’s the result:
File "", line 3, in
File "module:read_json", line 0, in lireDerniereCoordonnees
IOError: [Errno 2] No such file or directory: '/var/lib/ignition/data/mqtt_data_json/data_moxa-tbedb1004623.json'
So I have a file access problem on my Linux PC.
I already granted all rights to my .json.
Is it an issue somewhere in my script? Or an authorization problem?
What should I do?
Thanks in advance!
