jsonGet() Need Correct Path Syntax
I've tried to follow all the examples in this forum to get the function to return the 'cameraId' value from the following json:
{"dispositions":[{"scannedLabel":"m073770000100000000006700","cameraId":"2023031020313301672","inductNumber":0,"intendedLane":"123","actualLane":"123","labelStatus":"NORMAL","tiltTrayId":"TiltTray"}]}
The following Expression:
jsonGet({[MQTT Engine]IBM_MQTT/MHE/SORTER/DISPOSITION},'dispositions')
returns the following:
the following results in an expression error:
jsonGet({[MQTT Engine]IBM_MQTT/MHE/SORTER/DISPOSITION},'dispositions.cameraId')
It looks to me as though the jsonGet() function doesn't support nested paths. How did you get it to work at all?
I found a work around. I have a Document Expression Tag: 'dispositions' that has the following expression:
The 'dispositions' tag is referenced as the 'Source Tag Path' in a derived tag, 'dispositionTrigger' with the following Read Expression:
I don't think that's working because the JSON in the first parameter is working because it's being evaluated as a tag path. The nested path error is because of that. Try wrapping your test JSON in single quotes.
@hwbrill - you just need an array index in your JSON get expression? dispositions[0].cameraId.
that works too! Thank you @paul-griffith
