This tip can help you to determine the amount of time that has lapsed between two DATETIME values in MySQL.
I had a situation where I needed to determine the amount of time that had lapsed between (2) DATETIME values in MySQL. If you have run queries in Python you’ll know that a DATETIME value is returned as a string. So my first step was to find a way to convert the string to some type of Time or Date object in Python. I found that Python has a module called Time which has a function called strptime() which takes a string and converts it to a Time object. Just what I was looking for, only problem is that strptime() isn’t available in Jython 2.1, bummer. Then I found mktime() and it is available in Jython 2.1, problem here is that it converts a tuple into a Time object which meant I would have to parse the string value into a tuple which is more work than I wanted to do. I then looked to MySQL to try and solve my problem and that’s when I found UNIX_TIMESTAMP(). UNIX_TIMESTAMP() returns the number of seconds since 1970-01-01 00:00:00 as an integer. Using UNIX_TIMESTAMP() I could take the seconds of value1 and subtract the seconds of value2 and this would give me the amount of seconds that has lapsed between the two values. Here’s an example SQL query –
SELECT UNIX_TIMESTAMP(value_1) AS value_1, UNIX_TIMESTAMP(value_2) AS value_2 FROM table_name
I used the AS because the column names will be UNIX_TIMESTAMP(value_1) and UNIX_TIMESTAMP(value_2) if you don’t rename them.
I also found an unexpected benefit in using the UNIX_TIMESTAMP() function. If you have a NULL DATETIME value you will get the string value ‘Wed Dec 31 1969 18:00:00 CST’ in Python, I think this is because of the Java driver. But if the UNIX_TIMESTAMP() function encounters a NULL value you will get None in Python which is Python’s equivalent to NULL.
There are other Date and Time functions in MySQL that might come in handy if you need to do any kind of date or time manipulations in Python.
P.S. - Anything in the works to upgrade to Jython 2.2?
