Jython & java 2d library
hello i am new in this platform and i have core certificate but it's not enough to be administrator on scada project using this platform,the key to be ignition developper i need java.swing for module vision and in perspective i need to be expert with the css,any resources can help me to improve this 2 skills i don't need to have knowledge in java because using jython so any resources or softwares can help us to be more productive on this point,the basic component in igntion it's bade for the interface.
You shouldn't need any special Java Swing (or even Java) knowledge to develop successful projects in Vision. Sure, it can help you create some very advanced projects, but if you're new to the platform there's a tremendous amount you can do before you get that far.
I don't think you need to be an expert in CSS either, but some basic knowledge will probably help a lot. A quick Google search will turn up an amazing amount of free resources that will help you learn the basics.
W3schools will be your best friend !
