flavien
1
I have an array of JythonMap in my TimeSeriesChart. I would like to change t_stamp item to time item.
Is it possible ?
One element below :
"t_stamp": "2021-10-25 00:00:00",
"converted": "489.406",
"expected": "702.51",
"basic": "42.1",
"a0": "3.6"
This element after update.
"time": "2021-10-25 00:00:00",
"basic": "42.1",
"a0": "3.6"
Mu code below doesn’t work :
for row in value:
row['time'] = row['t_stamp']
del row['t_stamp']
lrose
2
Code works for me, at least in the Script Console, so I would expect it to work in other places, assuming that value is some type of sequence of maps.
If value is just a map, then this code doesn’t work.
Another option would be to use pop() to remove the item, something like:
for row in value:
row.pop('t_stamp')
Again, assuming that value is a sequence of maps.
flavien
3
for row in value:
row.pop('t_stamp')
Try changing it to Pydict with .toDict() or Java.util.map with .getRawMap()
You might have to convert to a dict before doing the assignment, or build a new dict from the JythonMap and use this instead:
return [
'time': item['t_stamp'],
'converted': item['converted'],
'expected': item['expected'],
'basic': item['basic'],
'a0': item['a0']
} for item in value
