Kafka publish to broker error
Hi.
I developed an ignition module that connects to the Kafka Broker(Confluent.io) and publishes messages to the topics. but get this errors:
[Producer clientId=producer-1] Connection to node -1 (bootstrap_server:9092) terminated during authentication. This may happen due to any of the following reasons: (1) Authentication failed due to invalid credentials with brokers older than 1.0.0, (2) Firewall blocking Kafka TLS traffic (eg it may only allow HTTPS traffic), (3) Transient network issue.
do I need to use truststore and keystore?
This seems entirely like a problem between your code and your Kafka server.
We have a first party Kafka client module coming in 8.3, for what it's worth.
Pssst! That's a terrible topic title--making our eyes glaze will not attract attention from helpful people.
I am so sorry! and thank you for correcting the title :pray:
Oh, nice! that's good news.
but as this is a custom module, I was wondering what part could be wrong @paul-griffith
this is my Kafka producer config:
 put("bootstrap.servers", settingsRecord.getKafkaServer());
            put("sasl.jaas.config", String.format("org.apache.kafka.common.security.plain.PlainLoginModule required username='%s' password='%s';", settingsRecord.getSaslUsername(), settingsRecord.getSaslPassword()));
            put("client.dns.lookup", "use_all_dns_ips");
            put("session.timeout.ms", 45000);
            put("acks", "all");
            put("security.protocol", "SASL_SSL");
            put("sasl.mechanism", "PLAIN");
could it be, that port 9092 is not open on the server ignition is running on?
I dunno, maybe?
My point is you're connecting a client you're authoring to a server you own/control. Ignition has ~nothing to do with this process. You're making an outbound connection, so Ignition's ports (which you're in control of also) are almost certainly not relevant unless Kafka works in some particularly weird way.
Might be worth checking this out. I know when we did implemented kafka (not in the above code), we did have to provide references to the correct trust stores and keystores.
