I have an opc connection to kepware on one Ignition, I have a second Ignition that I’d like to connect to the same opc server. Question, do I have to create 2 endpoints w/different port no. in Kepware or can I use the same endpoint for both Ignition’s opc connections?
You can use the same endpoint; from Kepware’s point of view, it’s just another client connecting in
