I have an older PC running WinXP with PKTX card communicating sto SLC 5/04 via DH+. This card is PCI and newer PCs no longer have PCI.
My plan was to install Kepware on this older PC and have Ignition connect via ethernet to connect to the SLC 5/04. I really do not want to use this older PC other than a gateway to DH+.
Is this doable with OPC-UA ?
You should be able to connect to Kepware on the older machine via OPC-UA, if that’s what you’re asking. (Assuming it’s a new enough version of Kepware)
Thanks Kevin.
Yes I am supplying newer version of Kepware, and will be connection to the older PC via OPC-UA.
