Kepware OPC-UA on 8.03 not connecting
Setup Kepware on its own server, Ignition recognized it and I trusted the connection in Kepware. But Ignition gives this error.
UaException: status=Bad_ConnectionClosed, message=connection closed
at org.eclipse.milo.opcua.stack.client.transport.uasc.UascClientMessageHandler.channelInactive(UascClientMessageHandler.java:152)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:242)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:228)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:221)
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:390)
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:355)
at io.netty.handler.codec.ByteToMessageCodec.channelInactive(ByteToMessageCodec.java:118)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1403)
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:912)
at io.netty.channel.AbstractChannel$AbstractUnsafe$8.run(AbstractChannel.java:827)
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163)
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:404)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:495)
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:905)
Have you trusted the Kepware certificate on the Ignition side as well?
Thanks for the quick reply. No, I don’t know how to trust it on the Ignition side. I just stepped through the OPC-UA set up with the end point and it showed up on the Kepware side. How do I trust Kepware on the Ignition side?
https://docs.inductiveautomation.com/display/DOC80/Connecting+to+Kepware+OPC+UA
Sounds like you’re somewhere around step 11.
That was it! Thanks!
