Keypad entry system that Ignition can connect to
Good morning,
Has anyone used a keypad entry system that Ignition can interface with? The user would type in their badge ID and Ignition would log that event.
An ethernet/IP solution would be ideal but I can work with anything if needed.
If you're talking about physical access control, ICT Protege GX has the ability to:
  1. Send XML event information over TCP
  2. Read/write to system outputs using Modbus
