I have a system with kiosk screens. When I tap my card it also enters a line itself in my value. I am using a text field and have 3 conditions to follow,
- If my length is < custom property altMax then my text field should refresh after 20 seconds as my user will be entering value manually
- If my length == altMax then my text field should refresh after 5 seconds
- If my text field contains a value and my user leaves the screen the text field should be back to " "
Here is a code that was working for the first two conditions
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
# Ensure the field does not take more than altMax characters
self.props.text = self.props.text[:self.custom.altMax]
# Import the necessary function for delayed execution
from threading import Timer
# Define a function to reset the value
def reset_value():
# Set the value to an empty string
self.props.text = ""
# Check the length of the currentValue
if len(currentValue.value) < self.custom.altMax:
# Set the timer for 20 seconds (20000 milliseconds)
Timer(20.0, reset_value).start()
else:
# Set the timer for 5 seconds (5000 milliseconds)
Timer(5.0, reset_value).start()
