KyvisLabs ApexChart Module
My heatmap isn't shading differently between values. I have the plotOptions.heatmap.colorScale.ranges.0 from 0.9 to 1.0. I also tried setting the plotOptions.heatmap.colorScale.min and .max and still not getting any shading.
Any advice?
I wrote a script to take the two colors and make a number of interpolated gradients between them. I bound this to options.plotOptins.heatmap.colorScale.ranges
    import json
    my_dataset = value
    # Assuming 'my_dataset' is your Ignition dataset
    test_index = my_dataset.getColumnIndex('TestValues')
    # Extract data from the 'TestValues' column
    test_values = [my_dataset.getValueAt(row, test_index) for row in range(my_dataset.getRowCount())]
    # Calculate min and max values of 'TestValues'
    min_value = min(test_values)
    max_value = max(test_values)
    # Calculate the range between min and max divided into 10 equal parts
    value_range = max_value - min_value
    step_size = value_range / 9  # Adjusted to 9 steps for correct interpolation
    # Generate the density ranges with interpolated colors and names
    value_ranges = [
            "from": min_value + i * step_size,
            "to": min_value + (i + 1) * step_size,
            "color": interpolate_color("#DCF0FE", "#008BFA", (i + 0.5) / 10),
            "name": "Relative Values {}".format(i + 1),
            "foreColor": "#000000"
        for i in range(25)  # Adjust gradient steps
    # Convert to JSON format
    json_value_ranges = json.dumps(value_ranges)
    return value_ranges
import colorsys
def interpolate_color(color1, color2, factor):
    """Interpolate between two colors."""
    r1, g1, b1 = int(color1[1:3], 16), int(color1[3:5], 16), int(color1[5:7], 16)
    r2, g2, b2 = int(color2[1:3], 16), int(color2[3:5], 16), int(color2[5:7], 16)
    r, g, b = [int(c1 + (c2 - c1) * factor) for c1, c2 in zip((r1, g1, b1), (r2, g2, b2))]
    interpolated_color = "#{:02X}{:02X}{:02X}".format(r, g, b)
    return interpolated_color
Does anyone know how to hide the top empty area of Apexchart?
Hey all, I just want to report a very weird behavior we have encountered with the Apexcharts module (v 1.0.16). It seems like events are triggered even if the chart is not in focus or covered by other elements. I tested markerClick and Click events, and they both register even if the event originated from a dropdown covering the chart.
In the video, I put as a reference also an icon with a onClick event on it. The icon correctly doesn't catch the event generated when clicking on the dropdown, but the Apexchart does. I tested this also with other native perspective elements and events are correctly not propagated if the element is not the focus of the click.
This has been tested on 8.1.35, 8.1.36, both in Chrome and Firefox.
Anybody encountered this behavior and/or has workarounds?Thanks in advance
Hello all, I would like few events on Apex Chart. One is requested in the forum post please find below link.
Another I would like to have a X axis label click event (xAxisLabelClick). Using this I would like to navigate to particular view.
Please let me know the solution for both the requirements.
It is an open source project. You can fork it, implement the feature, and generate a pull request. Small projects expect the person who wants a feature to provide the feature.
Thank you, Phil Turmel, However I am not a Java programmer, hence need some help on this. I thought that Travis will help me on this.
Travis (or Kyle) might help. But you say you have a requirement. In the open source world, that means you have to either do the work, recruit additional help, or pay someone to do the work. (If you can find someone willing to do it for pay.)
My favorite takeaway from that video is the arrow keys to change the day easily.
I don't understand it fully though. It looked like left arrow shifted the day back one.
Looked like right arrow bumped both days out one either side of the range.
I still want to implement some good radar charts.
Is really nice the Apex chart.
How are you putting "formatter": "function {val}... " into the tree of the props window? I am trying to round my Total value to my radialBar chart - but when I try to add formatter as a value (like I have "show": true etc) it obviously isnt working. Is there some tool I am missing? Seems like everyone is attaching the JS but you have to manually add to tree in perspective in the correct Value/Object/Array form
is depending, if you want to round in the tooltip you should use something like that in the formatter option function (value) { return value.toFixed(0);}
I have a general question about licensing. When adding the module to Ignition it shows a NOT VALID AFTER 05/04/2026 during the installation. Does this mean before or on that date during an upgrade we will need to reinstall the module to update that certificate? If we don't will the charts we are running in projects just stop working? This may be a dumb question but I just wanted to make sure as we are considering using this module for projects. Thanks!
Ignition ignores certificate dates. It shows them so you can decide, at the time of module install, if you care. The module will not stop working. (This isn't a licensed module, anyways. It's free.)
In new Ignition 8.1.39, the Apexchart component doesn't render and get error:
You should make a github issue reporting this.
I also did that, but may be someone here knows how to solve it.
Has anyone experienced issues with apex charts within the perspective IOS application? When attempting to use a line chart, the chart renders but the line is missing. This behavior does not occur on ios safari, chrome, edge, firefox, android perspective etc. It's only within perspective ios.Running 8.1.37. This happens with custom built trends as well as simply dragging an apex chart onto a view and leaving all the default values.
Thanks!
Yes, I saw that issue. Please report it on GitHub as well.
Looks like this was fixed in v 1.0.17 of the ApexCharts module: Releases · Kyvis-Labs/ignition-apexcharts-module · GitHub
Solved it for me, thanks for posting!
